| RRSPORT.CO.UK | ||
|  | Home > Technical > FIXED! ARC Suspension Fault - C1119 Hydraulic pressure |
| J50nmw Member Since: 01 Jan 2020 Location: Birmingham Posts: 15      | Hi I had exactly the same problem on my 4.2 supercharged 2005 and it was the pressure sensor on the side of the valve block I brought it back in Feb 2020 but the advert is still on ebay as per below its tough to change had to use a trimmed socket and then a spanner cut short to do it back up as the main pipes in the side of the block are slightly in the way
|  Sat Oct 16 2021 11:07pm |
| J50nmw Member Since: 01 Jan 2020 Location: Birmingham Posts: 15      | Here's a link to a valve block and it shows the sensor fitted in the side of the block on the second picture its the one on the left with the grey plug and wiring still on it to give you a idea of where it is
|  Sat Oct 16 2021 11:18pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | That's a good price if they are genuine L/R, bought from a Stealer and you won't get much change out of £200.00. Just for reference L/R part no. is RQH500020
|  Sat Oct 16 2021 11:28pm |
| blueraccoon Member Since: 03 Oct 2021 Location: Essex Posts: 9      | That's really helpful. Thanks very much. Will get one of these, fit it and report back.
|  Sun Oct 17 2021 4:11pm |
| blueraccoon Member Since: 03 Oct 2021 Location: Essex Posts: 9      | Ordered the sensor on the recommendation of J50nmw on Sunday and spent some time last night trying to loosen the old one off. Is a bit of a pain to get to but eventually got it loose by using a 27mm deep socket trimmed both ends and with the shoulder ground down.
|  Wed Oct 20 2021 6:07pm |
| Pastie4604 Member Since: 17 Oct 2018 Location: kent Posts: 3      | All, any ideas where to get an ACE Block pressure Sensor as no one seems to have a new one in stock, there are some 2nd hand ones around on eBay but I’d rather go with a new one? Thanks | ||
|  Tue Jan 04 2022 10:16pm |
| Mccolganm4 Member Since: 14 May 2021 Location: Dundee Posts: 68      | I know this a bit of an old thread but does anyone know if the link is still to the right part? It looks like a brake pressure sensor.
|  Tue Jun 14 2022 7:55am |
| Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84      | I think it may be RQH500020. | ||
|  Tue Jun 14 2022 8:34pm |
| Mccolganm4 Member Since: 14 May 2021 Location: Dundee Posts: 68      | Yeah that is the LR part number but it is not in the listing. I've took a punt and ordered 1(they accepted £50) I'll update when it arrives | ||
|  Wed Jun 15 2022 8:58am |
| Mccolganm4 Member Since: 14 May 2021 Location: Dundee Posts: 68      | For anyone wondering, the linked sensor was the correct sensor to replace my ACE valve block pressure sensor. | ||
|  Thu Jun 16 2022 5:16pm |
| Micaleff Member Since: 04 Aug 2023 Location: Colchester Posts: 7      | Mccolganm4 can you please send me a link of the sensor yu have bought? I am new to this forum and have excaty the same erorr codes showing on 2013 L320
|  Tue Aug 22 2023 10:06pm |
| Mccolganm4 Member Since: 14 May 2021 Location: Dundee Posts: 68      | Unfortunately that listing has ended. It was listed with a part number of 55cp13-02 which seems to come up as VW brake pressure sensor when searched on eBay now. They look the same to me but it's been a while since I done the job. They do look to be available for about £20 now though so probably worth a go. Good luck | ||
|  Wed Aug 23 2023 5:39am |
| Posting Rules
