Home > Faults & Fixes > Air suspension compressor
A4j1s0
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
2010 3.0D V6 sport facelift.
Started car in morning, warning only normal hight availible, this had happened ages ago.
Drove for a while, then Suspension fault.
Got it back home on deflated suspension.
Code read. Poor air supply.
Checked both fuses and 1 relay in fuse box by battery, all good.
Removed pump and bench tested with direct 12v supply to main wiring coupler and pump works.
And ideas please.
Another fuse or relay somewhere.
Pump still on bench at the moment.
Thank you.
Simon.
Post #635183 Sun Aug 20 2023 6:11pm
Stevepd
Is it possible you could have a bag leak. Others with more knowledge will be along......... 2006 2.7 TDV6 HSE in Cairns Blue.
Post #635190 Mon Aug 21 2023 6:34am
The bags very rarely fail. More likely is crud from the drier getting and causing valve issues.
Strange that it's dropped on to the bump stops. That's also a sign of a problem with the ride height sensors giving spurious data causing a "cross axle failure". 2012 SDV6 - it's missing a couple of cylinders
Post #635195 Mon Aug 21 2023 9:18am
Disco_Mikey
Just because the compressor runs, doesn't mean its putting out adequate pressure
Post #635198 Mon Aug 21 2023 10:23am
A4j1s0
Thank you for your help and replies.
Have decided i need to purchase a more dedicated diagnostic reader.
Suggestions please.
Prefer dedicated land rover system
Thank you.
Post #635301 Thu Aug 24 2023 6:10pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
There is a gap to in the for sale section you can not get better
Post #635309 Thu Aug 24 2023 8:18pm
Hightimo
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Definitely go for a Bluetooth gap one - save you a fortune and will do everything you need and more .
As disco_mikey states the compressor could be on the way out but still work on bench - mine wasn’t getting to pressure as it was worn and gave the same fault initially
Post #635467 Thu Aug 31 2023 6:11am
A4j1s0
thank you all for your replies.
purchased a used Gap 11 reader.
still not managed to get it linked to my vin.
managed to read code C1131-92- air supply component failure or incorrect operation (2A)
any suggestions what component might be at fault.
many thanks.
Post #636245 Sat Sep 30 2023 4:45pm
A4j1s0
So just a quick update.
Compressor rebuilt with viton seal kit.
All fine.
Found pipe from dryeroutlet to valve block leaking.
Sorted with billet end.
Fitted and started, still low air pressure.
Inlet/ ehaust line and filter appear to be blocked,
Disconnect both pipes and car is fine.
Hope this might help others.
Post #636736 Sun Oct 22 2023 4:45pm
