Home > General > Keyless entry
geezerjoe2023
United Kingdom 2011 Range Rover Sport Supercharged Autobiography Santorini Black
Keyless entry
Is it’s possible to disabled this?
I have tried to already using the YouTube videos on my 2011 RR sport autobiography but it doesn’t work
Software update needed maybe?
Post #635093 Wed Aug 16 2023 4:53pm
Although I do have it enabled now, I did disable mine out of curiosity using a video method by If I remember right a "Les Potts or someone like that off Youtube, I did however have to have several goes to get it to work and disable the system.
Post #635098 Wed Aug 16 2023 9:48pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Not sure why, but there are many reports of battery drainage after keyless entry disabled …
Post #635099 Wed Aug 16 2023 10:21pm
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Hi Col,
I've been trying this on and off for a few months now on my RRS but I'm unable to disable keyless entry. I've watched the videos and read peoples comments but all to no avail.
Is there anything different with the facelift models ?
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #635252 Wed Aug 23 2023 6:29am
Hi Craig,
Not that I am aware of, some people do seem to manage it with no problem, others can't seem to get it to work, I believe there is a physical difference in the key fobs between the earlier and later cars the later being more compact, but can't really see that making a difference. I do seem to remember they did upgrade the KVM module software a few times as a security fix to try and help prevent theft of the vehicle "that was something else L/R tried that nearly worked" Rolling with laughter whether that could be the difference making it easier to disable on later cars I wouldn't really know, not sure if they ever did a recall on earlier cars either for a software upgrade.
Post #635255 Wed Aug 23 2023 6:54am
Jabba
Yes its very strange and annoying.
I did find another member that had a similar issue whereby he was unable to program a new key and also unable to disable keyless entry. He contacted GAP and Patrick sent a new file to flash his key module with, this resolved both problems, that was on a MY13 L320.
Maybe I need to ask GAP the same question.
Many thanks
Post #635258 Wed Aug 23 2023 8:56am
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
This worked for me on my MY 2010 L320 3.0 TDV6
https://www.facebook.com/lespotts4wheeldri...120106801/
No battery probems since
Post #635410 Tue Aug 29 2023 4:17pm
Jabba
An update, I contacted Patrick at GAP and explained my issue. Patrick asked for my ecu info, which I sent. He then sent me instructions to update my GAP tool with an ecu flash update only.
I have applied the update to my KVM ecu today and tried the disable keyless entry again, unfortunately this didn't work.
Patrick informed me that It's all handled by the KVM ECU and some dont seem to support disabling, earlier hardware especially which is what I have.
So that's that then Crying or Very sad
Many thanks
Post #635500 Fri Sep 01 2023 4:03pm
Goffy
My car (3 previous owners) came with only one key, so I asked my indie to get another for me. It couldn't be programmed because the KVM module wouldn't permit it.
Apparenly there were 3 generations of KVM:-
1) anbody could programme a new key
2) keys could only be matched at manufature of the vehicle (this is what I originally had)
3) dealers/indies with the right kit can program new keys and keyless entry can be disabled as above
I now have version 3 so I can disable keyless entry - but it did cost me for a new KVM module.
Post #635541 Mon Sep 04 2023 11:26am
Jabba
Hi Goffy,
That's interesting, thanks.
Do you have a part number for your V3 KVM ?
Many thanks
Post #635542 Mon Sep 04 2023 11:46am
Goffy
Alas, no, the part number is not listed on the invoice.
But the price is recorded as £198.47 back in 2018 - ouch!
Post #635544 Mon Sep 04 2023 12:09pm
Jabba
Thanks Goffy, I'll have a read around Thumbs Up 2010 RRS 3.6 TDV8 HSE Galway Green
Post #635545 Mon Sep 04 2023 12:30pm
Google LR071386 I think not totally sure though.
Post #635546 Mon Sep 04 2023 12:49pm
Jabba
Thanks Col, I found this one LR071651 on
https://parts.jaguarlandroverclassic.com/p...and-rover/
But not sure
Many thanks
Post #635547 Mon Sep 04 2023 1:03pm
I may have it wrong, but I think LR071651 could be keyless start only and LR071386 is passive entry and keyless start, proably best to check with dealer to be sure.
Post #635571 Tue Sep 05 2023 11:17am
