Home > General > Aircon issue… cold for passenger, warm for me…
Farmer Chalk
Anyone suffered this issue? 2020 L494 Aircon working fine until recently..was working hard for two weeks on our trip around southern Italy in 35-40 degree heat..
Got home and almost immediately I got the feeling that it wasn’t working properly.. last couple of warm days in the UK I have been slowly stewing..
Aircon on left side of car working perfectly.. with cool air coming out of all the left hand vents.. however on the drivers side vents it is blowing out warm air…
Thoughts? In the old days I would have said a blend motor but I am unfamiliar with latest JLR products? Is there a split channel on 494 compressors? Does it use a second rad? Etc etc..
Grateful for opinions!
FC…
Post #634992 Fri Aug 11 2023 9:16pm
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Eh up,
Just a thought as I had the same on my BMW HVAC system, was the stepper motor that went?
Same symptoms as you have.
I am sure someone on here with more knowledge will be able to assist better but hope this is at least something to consider
HTH
Post #634993 Fri Aug 11 2023 9:31pm
Farmer Chalk
That’s what I am hoping it is ….however I am surprised it knocks out all right hand vents.. if it was that I thought it would only affect one of the vents but this is windscreen, face and side vents and footwell vents as well…
The car still has the approved warranty on it and thus a stepper motor is a warranty issue but a hole in one of the condenser rads is likely to cost me large…
Post #634995 Fri Aug 11 2023 10:05pm
TTR
Eh up
I’m no expert on air con ( other than tonight when I refilled my E90 with a DIY kit and worked a treat)
Not sure if a split system on yours with condensers serving each side, could be but would mean over complicated systems.
Does all other HVAC systems work other than air con on drivers side?
Can you use a temp gun to get readings just to make sure even on hot it’s balanced, also have you tried air con switched on but turn temperature up so it’s heating .
See if it’s still balanced with heat running through
Hope that makes sense
Post #634996 Fri Aug 11 2023 10:34pm
Farmer Chalk
Good idea.. will give it a try! Let you know!,,
Post #635026 Sun Aug 13 2023 9:26am
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Not a RRS but I had a the same problem with my Ford Transit Connect. A simple re gas sorted it out so could be something as simple as that.
Post #635031 Sun Aug 13 2023 3:53pm
Farmer Chalk
Thanks all… currently at the dealers as hopefully it’s still warrantied
Searching the forum it does appear to be a common problem and as John has highlighted and confirmed by the dealer it is low on gas and apparently and I don’t know why, when it is low cool air comes out one side only…
The dealer now reports that it is blowing warm out of both sides… the issue now becomes where is it leaking from.. I am hoping that it’s not the condenser rad which is unlikely to be covered..
Fortunately it’s timing is perfect.. just got back from a grand tour of Italy where it was coping well on days where we had 40 degree heat.. back in Blighty where it’s rainy and miserable and it gives up the ghost… maybe it’s depressed?
Post #635156 Sat Aug 19 2023 8:42am
TTR
Eh up Farmer Chalk
Glad you got it sorted Thumbs Up
Post #635173 Sat Aug 19 2023 7:57pm
Farmer Chalk
Not quite but i will keep you posted on what it turns out to be!
Post #635175 Sat Aug 19 2023 9:50pm
Farmer Chalk
Right everybody I now have a definitive answer… it was a split condenser rad. The loss of Aircon gas/fluid was creating the cold on one side through the air vents issue. So John and TTR were both right!
Thank you!
Even better was that it was covered under warranty as it was a split rad and not a holed rad! The condenser rad is the large one at the bottom. If you look through the lower front bumper grills it is that one..
So well pleased as my car temp is nice and chilly again!
Thanks all and hope this thread helps others in future!
Post #635220 Tue Aug 22 2023 1:18pm
