![]() | Home > General (L494) > L494 P400e or D300 or P400HST |
DrRick Member Since: 24 Oct 2011 Location: Edinburgh Posts: 54 ![]() ![]() ![]() |
So our 2017 SDV6 at 56k miles is starting to give up more times than is reasonable. It was an Approved Used, but still. We're now on the lookout for a replacement and have had all manner of LR products: FL2, Evoque, several D4s, several L494s and a D5 with the dinky engine (what a mistake).
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9115 ![]() ![]() ![]() |
If you're doing lots of short, local journeys, diesel doesn't make any sense these days. The DPF will hate you, for one thing. 2012 SDV6 - it's missing a couple of cylinders
What sort of things are going wrong? Is it cheaper to replace or just fix what you have? Do you use an LR dealership or an independent? A decent indie will be cheaper and do a better job resulting in a happier ownership experience. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1909 ![]() ![]() |
Well I would go for the P400e if you can charge overnight at home for 7.5p a Kw/hr with Octopus.
So far, we've had to replace the ACE pump, the valve block for the active roll system, the main battery and now I think the suspension height sensors at the rear (front suspension isn't playing up, but the rear is).
We're not on a 'clever' utility package at the moment. Thanks to the recent economic meltdown, we're one of the unfortunate lot who were on a 'decent' / cheaper supplier who went bust and we were shunted to British Gas for our sins. Now waiting to get a sensible deal somewhere that won't bankrupt us. |
Have you looked at Octopus?
Ah, yes, if SWMBO has decided it's not for her then that's basically it done. Sounds like you've been unlucky with the Dynamic Response system if you've needed a pump and valve block. Battery is a consumable item, frankly, once it's a few years old. Height sensors is an strange one. One going, maybe, but two would be most unusual. What's it doing at the rear? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Oh yes, the (consumable) rear flexi hoses for the brakes are due to be replaced before the MOT as they’re corroded, and the parking brake is grabbing / dragging on release. Think it’s doing the suspension back from levelling itself, and there’s an audible clunk from the near side rear and a little jerk as the car levels.
DWA Member Since: 06 Jan 2022 Location: Scottish Borders Posts: 22 ![]() ![]() |
Going by your choice of P400e looks like you are going with another L494, this might not be too pc on a RRS forum and I'm probably going to get shot down in flames, but reality is and I say this as a Land Rover pervert of 30 ish years, but how long is another L494 going to solve your problems for. I know loads are running every day and never put a wheel over a garage door, but I also know mine has it's fair share of problems as do loads more and so has every Land Rover I have ever run from Freelander to RRS and every one in between. Just putting it out there as food for thought after all that's what these things are all about. |
We've had a bunch of LR products....and one BMW equivalent. We're also well scarred by the fact that LR vehicles have high bork potential....yet we still come back.
I know the problem, had enough of Land Rover a few years back and went to the dark side and bought an
The new LandCruiser very much doesn't compete with the RRS, however. It's aimed at those that need/want off road ability and the ability to modify it for serious off road use. It's not competing in the luxurious, off road-capable, sports-limo category in which the RRS really finds itself. 2012 SDV6 - it's missing a couple of cylinders
Indeed, my formative years were Wadi Bashing in Oman in the back of a Nissan Patrol. Group of like minded expatriates, no plans, no emergency cover, limited resources but it just worked. It was desert, rocks and heat.
