Home > General > Replacing ECM LR12730
DirtyApe4x4
United States 2011 Range Rover Sport Supercharged HSE Santorini Black
Unfortunately need to replace ECM LR12730 on my 2011 RRS HSE…pitfalls to beware of using a used part (Other than it’s busted too)? New one is $2100-$2300 while a used one is under $200. Doesn’t seem like these are common fails but for the price difference I could swap one out a number of times and still be under budget on a new one.
All experienced advice welcome! 2011 Range Rover Sport GT Limited Edition/Santorini Black 5.0 Liter
2009 Jaguar XK Convertible Diamond Edition/Pearlescent White 4.2 Liter
Post #634779 Thu Aug 03 2023 3:27pm
Engine module. They contain the imboliser code usually so a replacement won’t just work unless
A) you reprogram it. or
B) you buy a kit of parts available of eBay. Ecu cjb, instruments, key
Post #634780 Thu Aug 03 2023 6:22pm
DirtyApe4x4
Thanks - it will be reprogrammed, I didn’t know if anyone has had issues trying to rewrite with new VIN… 2011 Range Rover Sport GT Limited Edition/Santorini Black 5.0 Liter
Post #634784 Thu Aug 03 2023 11:42pm
Only a question, is car your car a S/C or N/A? only apart from a digit (0) being missing from part number you quoted that is for the N/A.
Post #634785 Thu Aug 03 2023 11:49pm
DirtyApe4x4
It’s not the supercharged…USA regular old HSE petrol…part number came from dealer. 2011 Range Rover Sport GT Limited Edition/Santorini Black 5.0 Liter
Post #634786 Fri Aug 04 2023 12:17am
Thumbs Up I think the part no. should be LR012730 unless for some reason they drop the "0" in the States.
Post #634787 Fri Aug 04 2023 12:34am
DirtyApe4x4
You are correct! Should have the zero…got lost in translation…thanks for noticing! 2011 Range Rover Sport GT Limited Edition/Santorini Black 5.0 Liter
Post #634788 Fri Aug 04 2023 1:01am
DirtyApe4x4
    I’ve ordered a used one for $127…….new as stated was was $2300…the dealer is actually willing to install the user part and reprogram. Charging 2 hours labor for install & programming. Part arrives early next week, I’ll update you on the success…
Post #634837 Sat Aug 05 2023 2:07pm
DirtyApe4x4
###update###
Well, dealership agreed to install my used part, reprogrammed it and all is well! Ended up the cost of the part & 3 hours labor for initial diagnoses/failed program, part install & reprogram. Saved a whopping $2200 by not having to buy new. The part seller even warned me that the dealer wouldn’t help me so I guess I was quite lucky to have a dealer that cared to help…well done Land Rover Dayton (Ohio,USA)! 2011 Range Rover Sport GT Limited Edition/Santorini Black 5.0 Liter
Post #634974 Thu Aug 10 2023 10:50pm
