![]() | Home > General > No crank no start, lights flashes on the dashboard |
kas982 Member Since: 03 Oct 2021 Location: west mids Posts: 53 ![]() ![]() ![]() |
is your vehicle right or left hand drive? if rh, then is suspect you have water ingress hitting the fuse box. also remove battery & check ecu for water damage. |
Willie T Member Since: 27 Jul 2023 Location: West Africa Posts: 7 ![]() |
Thanks for your reply.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 748 ![]() ![]() ![]() |
1. Water ingress around the base of the right-hand (passenger) A-pillar.
Here's an example: https://www.facebook.com/JASLandRoversLtd/...55/?type=3 Regards etc.,
Thanks for your help.
These are the lights flashing on the dashboard
An E stands for gearbox error.
Thank you so much for your help.
Peter tarabay Member Since: 27 Jul 2024 Location: Abi safaa el din road Posts: 1 ![]() ![]() |
Hii sir i have the same problem of the photo that you posted Please can you share the solution? |
