![]() | Home > Faults & Fixes > Battery ? |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
I would be looking at your alternator,, check your charging voltage,, and if you have a clamp meter, the current. Wouldn't cost anything to check the battery terminals either making sure they're tight. I had a similar issue thinking it was the battery I changed it,, but the battery died for no reason one night. Put it down to short runs in winter but noticed by accident that on a 20 milers the battery voltage dropped to 13.5V for a short while. Thought no more of it then the alternator failed a couple of weeks later. 2010 RRS, TDV8
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
Initially I would have thought the battery has a couple or so dead cells that won't hold charge, what age is the battery?
Motorman Member Since: 28 Jun 2023 Location: Elgin Posts: 19 ![]() ![]() ![]() |
The battery is a good age Ive got another one coming just hoping its not something draining the battery |
Ahh,, I assumed you had fitted a new battery,, but if your still using an old one I completely agree with Col,, definitely sounds like the battery is only holding a small amount of its capacity,,,,, but check your charging rates as a matter of course. 2010 RRS, TDV8
Hi
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9151 ![]() ![]() ![]() |
It does sound like a dead cell in the battery. The battery charger can only do so much - once the cell is dead, it's dead. You get an apparent ok reading after charging because the plates have an excess charge on them initially so it reads good. Once that surface charge dissipates (over several hours), you get the true reading.
Hi
