Home > Faults & Fixes > Help is it instrument cluster or something else
Keith43
Hi guys got several problems
I know range rover sport hse 2.7 tdv6 and all that
But here goes :-
There were no check engine warning on dash or error lights on dash my cars being sat in my garage whilst the bodykits being sprayed at paint shop so good few weeks work strip paint refit etc whilst at spray shop
In meantime cars in my workshop/garage sat there waiting not used.
First fault was heated rear screen didn't work called auto electrician out he tested it said relay in main body control module relay for heated rear screen was stuck open two choices new main body control module or fit external relay
I found a company( via Facebook member recommendation) that does body control cloning/ copying posted off the main board and cloned board they came back we re fitted cloned body control module
Started car heated screen worked everything worked all of sudden dash lit up like Christmas tree every light every warning message you could think of came up on dash (first thought was dash failure )
I read 85 codes on ECU via obd port and cleared all old codes
Then re read ECU codes via snap on machine and see screenshots can you please give me some advice other than scrapping it
The radio isn't in the car nor is the top information screen as waiting for the Tesla screen install so that explains audio faults
But I'm also getting irrespective of board I use the same codes how do i fix
[img]
Post #633843 Tue Jun 20 2023 6:10pm
RRS112
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Santorini Black
Hi there
I have the exact same issue have you had any joy getting a resolution. I have bought a brand new cluster but I can't get anyone to code to the car. Any and all help gratefully received
Post #634640 Sat Jul 29 2023 10:38am
skid1963
Have you checked the battery is ok??
These cars can throw all sorts of faults with a faulty battery or not enough charge in it, i notice on some of your screenshots the engine is not running, it doesn't take long for the voltage to drop with everything switched on without engine running.
Also i note you say it's been standing for a while in your workshop, do you have a it on a battery maintainer or anything? 2015 L494 SDV6 3.0 HSE Loire Blue
2006 L320 4.2 Supercharged - Gone
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #634646 Sat Jul 29 2023 2:17pm
Crs
England 2013 Range Rover Sport Supercharged Autobiography Firenze Red
I all so would say give the battery a good charge, I put an optimate charger on my 2 every other week until they show the battery is full charged, and I am using them not sitting for weeks.
Post #634647 Sat Jul 29 2023 2:54pm
RRS112
Thanks Skid new battery fitted car was in garage and all faults cleared and within a day or so it brought up the codes again. I have had the suspension checked and looks like it needs 2 lower arms on the front which can apparently cause issues with the steering dwell sensor so will do the arms too just in case
Post #634654 Sat Jul 29 2023 7:16pm
