Home > Faults & Fixes > L494 Sunroof and sunroof blind
hario69
I have a Feb 15 (pre facelift) RRS 3.0 SDV with pan roof
The sunroof blind is stuck open and won’t close, and now the sunroof won’t open either - it moves back an inch and the closes itself.
It did something similar a year ago and the reset procedure of hold down close for 20 secs worked. It’s not working this time.
Any ideas? Thanks
Paul
Post #633808 Sun Jun 18 2023 4:55pm
Karlp606
Maybe disconnect battery for 10 minutes and reconnect might help clear any fault code.
Post #633809 Sun Jun 18 2023 7:31pm
hario69
Thanks - I’d be Censored it that I’d lose all my settings at the same time - seats, stereo, radio/tv stations and also Fek something new up.
Would I lose all that info do u think?
Post #633810 Sun Jun 18 2023 8:20pm
Karlp606
You would only lose the stored DAB channels.
Or you can pull the fuse for the sunroof/blind 1st for 10/20 mins see if that helps
Post #633819 Mon Jun 19 2023 11:17am
hario69
Great call on the fuses - I’ll try that. Don’t suppose u know which number fuses and which fusebox? I’m at work and could have a crack at this before I go home
Thank you 👍
Post #633821 Mon Jun 19 2023 12:18pm
Karlp606
Not sure pal, google fusebox locations l494 and you should find something.
Post #633830 Mon Jun 19 2023 3:56pm
Russtyp
There are two fuses in the passenger fuse box.
Numbers 7 and 28 one for the blind and one for the sunroof
Post #633845 Tue Jun 20 2023 9:38pm
hario69
Pulled the fuses, still no joy. Fek. Got a feeling this is going to be messy
Post #633929 Sun Jun 25 2023 3:27pm
