Home > General (L461) > Massive ‘hair drier’ noise from the engine when charging
Cantona
New p440, done 4500 miles. Strange (loud) fan type noises going on and off when in charge. Is this normal?!
Post #633759 Thu Jun 15 2023 9:22pm
TheWojtek
Battery needs cooling down while charging. Not so apparent in winter, quite noticeable in summer. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #633760 Thu Jun 15 2023 10:18pm
Cantona
Many thanks Wojtek.
Post #633761 Fri Jun 16 2023 5:35am
Claud
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
I had the same issue a couple of days ago charging the car with a car cover on. The cover blocked the air intake on the front and subsequently the cooling fans went into a spiral of faster and faster rate. As soon as I removed the cover off the front of the car, the fan rate dropped.
I have now decided I need to keep the front of the car uncovered when charging to avoid the overheat issue in summer. RRS Autobiography P460E
Post #633805 Sun Jun 18 2023 12:49pm
