Home > Technical > front active roll bar
maci234
which bushes does most recommend for the front active anti roll bar and also the drop links l494 2013
Post #632902 Fri May 05 2023 9:25pm
Disco_Mikey
Genuine bushes
OE (Delphi) drop links
Bolts should be replaced when replacing ARB bushes, and tightening torques are a lot tighter than you'd think Shocked
Post #632903 Fri May 05 2023 9:34pm
maci234
thanks do you still use poly bushes .better gen or poly
Post #632904 Fri May 05 2023 9:36pm
Disco_Mikey
Don't use Polys on the aluminium things...
Post #632907 Sat May 06 2023 5:32am
maci234
thanks
Post #632910 Sat May 06 2023 12:13pm
maci234
replacing ARB bushes, tightening torques for bolts
Post #633577 Mon Jun 05 2023 11:02pm
L494 workshop manual here: https://www.mediafire.com/file/5hmml7nd29gabm0/RRSL494WSM2014.zip
That'll have the torque figures you need. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #633586 Tue Jun 06 2023 10:37am
