Home > Technical > Coolent level low light on
Barry webb
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Hi everyone this is my first post.
I had the low coolent light come on so pulled over and called the AA they found the someone has not fitted the top hose correctly it should just clip in so he did the repair for me but dud not have any antifreeze only water to top up the system.
All fine now no leaks from the clip on hose and water in the tank up ti max but the low coolent level light stays on it says press OK to clear but still keeps coming on do I need a new sensor or is it because its low on antifreeze.
Barry.
Post #633495 Thu Jun 01 2023 10:25am
Karlp606
Hi , no you will need to drive the car for abit and this will clear the stored code.
Obviously long as you have enough coolant/water in.
Post #633498 Thu Jun 01 2023 11:04am
Barry webb
Thanks for your reply I've been driving it around fir about a month now and its coolent level is good but light still stays on.
Post #633501 Thu Jun 01 2023 11:48am
Karlp606
Ah okay!
I had the same issue, coolant hose left loose, lost coolant , put coolant in and it cleared the code.
Prob need a OBD scanner to clear the code as its stored it or disconnect battery for 10 mins.
Post #633502 Thu Jun 01 2023 11:50am
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi if there are no leaks now and the coolant level looks fine the level float in the expansion tank is saturated and sinks to the bottom.You need to change expansion tank. Thumbs Up
Post #633507 Thu Jun 01 2023 5:30pm
Barry webb
I have disconnected the battery for 30 mins and on reconnecting the warning light is still on I have two cheap plug in hand held machines and both say no codes to clear.
Post #634425 Thu Jul 20 2023 3:42pm
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
Sticking float switch in expansion tank, quite common!!
Pop a new expansion tank on and you will be good to go.
Regards
Post #634430 Thu Jul 20 2023 5:49pm
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
As above. New expansion tank (with sensor) needed. Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #634440 Fri Jul 21 2023 6:56am
Barry webb
Hi I have the tank with the small push in sensor.
Up date I have just had a genuine sensor fitted and still have the same warning on low coolent level it's been put on a expensive fault reader and it can't find any faults at all yet the warning is still on and coolent level is at normal.
Post #634791 Fri Aug 04 2023 8:37am
Did they replace the sensor or the whole float unit? If the float sticks down, the sensor can't give any reading other than low. 2012 SDV6 - it's missing a couple of cylinders
Post #634792 Fri Aug 04 2023 10:43am
Barry webb
Hi there is no float system it's just a tank with a stuck like sensor.
Post #634799 Fri Aug 04 2023 3:53pm
Iomegas
There is deffo a float after time it becomes saturated and sinks to bottom of tank causing the alert.Replace the tank problem solved.
Post #634801 Fri Aug 04 2023 4:15pm
Float is part of the tank.
The whole tank has to be changed
Post #634802 Fri Aug 04 2023 4:24pm
Barry webb
Hi I have spoken to the with the guy doing the job for me and he confirmed there is no float in the tank only the push in sensor that he has replaced with a genuine part see picture of the sensor.
Post #634803 Fri Aug 04 2023 5:04pm
Iomegas
Well it must be stuck on the bottom but there is deffo a float that moves up and down with the level as said they become saturated and sink to bottom.The tank itself cones with a sensor when you buy new one .The tank itself is easy to replace.
Post #634805 Fri Aug 04 2023 5:47pm
