Home > Technical > Epb unit
jk3528
Epb unit
Ok so what else is controlled by the Epb unit does it do things like steering angle? traction control?
It get’s power from all 3 feeds but the iid tool is telling me it’s the switch but I now have the traction control coming on when I go round a roundabout
So could it be the unit that is faulty not the switch?
Post #633302 Tue May 23 2023 9:07am
The problem is that the EPB module (which controls the EPB system) is connected to the switch and also to the CANBUS. So you can get cascade failures caused by something else throwing a fit.
For example, the EPB module will ask the ABS system to apply the main brakes if the switch is pulled and held at speeds above 10km/h - so called "dynamic apply mode". So a problem in either the EPB, the switch or the ABS system could throw an error up. 2012 SDV6 - it's missing a couple of cylinders
Post #633303 Tue May 23 2023 9:24am
jk3528
If I could sort out which wires in the switch are connected when not operating I might be able to bypass it and see if that stops the fault from showing up
Post #633305 Tue May 23 2023 10:06am
You may as well clean the inside of the epb switch (it’s like a tv remote control) or get a second hand one
Post #633310 Tue May 23 2023 11:22am
Assuming you have an L320, the workshop manual is here: https://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf
There is a section on the EPB and the wiring layout is shown in the wiring diagram section.
Good luck. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #633317 Tue May 23 2023 12:49pm
jk3528
Yes it’s a 2006 l320 2.7v6
Thanks
Post #633330 Tue May 23 2023 8:06pm
Pufftmw
The other thing that could be initiating the traction control is a sticky front left calliper (seeing as its a roundabout). Happened to me, took me a while to work it out.
Post #633333 Tue May 23 2023 9:00pm
