Home > In Car Electronics > OEM headunit: which one
ax_crosser
Belgium
I've recently bought a TDV8 from 2009 where the previous owner changed the headunit to an aftermarket one from Pioneer. But he did not do it entirely correct so the display in the dash is "stuck" on the LR logo. I searched the forum already for the proper way of doing that, but I will fiddle with that in the future.
I want to change the headunit back to an OEM one (so the display works again), but the original headunit did not come with the car so I want to buy a secondhand OEM one. I'm not sure if there are different versions of headunits depending which sound-system the cars had?
Can I just buy whatever OEM headunit and will that work, or do I need a specific partnumber?
I think my car is fitted with the Logic7 system.
Post #633281 Mon May 22 2023 4:04pm
TheWojtek
Any will do, three are available, two of them will fit your car: single-disc CD player and 6-disc changer. The latter has "465" type marking, if I remember correctly. In general - any headunit that has the green display slightly offset to the right side.
The amplifier, tuner and TMC module are located in the trunk area, so the actual headunit acts as the user interface and a junction for various connections, copper and optic fibre. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #633283 Mon May 22 2023 4:51pm
You need the unit with the optical fibre connection at the rear.
A 6 disc model should suit
On pre facelift the amp is under the seat, and tuner built into the headunit
Post #633286 Mon May 22 2023 6:04pm
TheWojtek
I stand corrected, thanks Andy. Regards etc.,
Wojtek
Post #633288 Mon May 22 2023 6:55pm
ax_crosser
Belgium
Thanks for the info guys!
Post #633327 Tue May 23 2023 6:13pm
John R Hickman
England 2009 Range Rover Sport TDV6 S Santorini Black
CD560 is a single disk player with built in amp and MOST socket for screen. CD565 is 6 disk player without built in amp and uses the MOST to connect to amp and screen. Interestingly while I had my single disk player out I plugged in a CD465 6 disk from a disco and it worked the screen and connected to my phone via blue tooth obviously no sound as I don't have the amp under the seat. So any 6 disk player should work if you have the separate amp. Just be aware though that the disco one has a different fascia shape at the bottom and won't fit without modification even though they look the same. 2008 RRS 2.7 TDV6 S Poverty model
Post #633356 Wed May 24 2023 11:54pm
