Home > Technical > 2005 L320 Headlight flickers then goes out
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
Not sure how to explain. When I turn on the car, the LH headlight (headlamp for you brits!) turns on - albeit a different color to the RH one - and then often it will rapidly flicker and turn off. Seems to work again when you turn the car off and restart it, but then the light does it again.
It started doing it very intermittently a week or two ago, but now seems consistent.
Could this be bulb or ignitor or something else? I'm thinking I might swap those parts one by one to the RH unit to see if the issue follows one of them.
Has anyone seen this before? Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #633179 Thu May 18 2023 10:44pm
If the bulb is showing a different colour I would suspect the bulb maybe is on its last legs, initialy I would just swap the bulbs to see if it proved anything.
Post #633180 Thu May 18 2023 10:51pm
Disco_Mikey
When the bulb goes blue/purple, instead of white, that's a dying bulb Thumbs Up
Post #633184 Fri May 19 2023 6:29am
frostmotorsport
Disco_Mikey - that is exactly what has happened. I will get new bulbs. Legend, thank you! Every home should have one!
'04 Audi S4 Avant
Escort Mk II Sport
Post #633185 Fri May 19 2023 6:31am
