![]() | Home > General > TDV8 Oil Cooler |
That is odd as there is a 15 page section dedicated to removing the oil cooler in the copy I have, it also looks like it is a 'O' ring seal where the cooler mounts to the engine not a gasket.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 420 ![]() ![]() ![]() |
The workshop manual that I have doesnt have a 15 page section dedicated to the oil cooler removal. Can you point me in the right direction where to get this. |
Can some one point me is the right direction for the oil cooler removal procedure.
You need either the 2007-2009 or 2010-2011 edition of the workshop manuals then for the TDV8 engine then.
Thanks |
I am about to order parts for the oil cooler leak. I was looking at replacing the EGR valves at the same time. Are there any other part I should consider getting so that I only have to diassemble the inlet manifold once. |
haydent Member Since: 16 Apr 2025 Location: NSW Posts: 3 ![]() ![]() |
hi , im chasing this manual with details of the oil cooler and cant find it anywhere, thanks |
