Home > Technical > Non-starter after service
djpgowrie
So this is the 3rd year I've done my own service and the past 2 years have gone perfect.
Today I replaced oil filter, fuel filter, air filter, cabine filter, ACE filter, oil, coolant.
However, the car started then quickly stalled after maybe 5 seconds of running and hasn't started since. My first thought is fuel starvation and after doing a live scan with my iCarsoft I can see the fuel rail pressure is 1.14 MPa (desired says 30MPa).
I bled the system and there fuel flowing out of the Schrader (sp?) valve.
Anyone have any ideas what caused this? Could it be a dodgy fuel filter?
Post #632924 Sun May 07 2023 4:59pm
gogsy1956
No so familiar with your model but you say you've bled the fuel through and it started then died,,,, I would be looking at your fuel pump. Your live values indicate low pressure but not sure if this with ignition on or when trying to start etc. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #632935 Mon May 08 2023 9:28am
djpgowrie
So this morning I cracked the high pressure pipes to the injectors and had zero fuel coming through on crank.
Fitted the old fuel filter and all is well again.
Faulty fuel filter from factory... FML
Post #632946 Mon May 08 2023 12:51pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Good result👍🏼
Post #632954 Mon May 08 2023 10:16pm
