Home > General > EGR Valve Won’t Open - how soon do I need to get this fixe
Josh95
Northern Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Java Black
RRS 2012 V6 117,000 miles on the clock.
Have occasionally been getting an amber engine monitoring light on the dash. Took it to get diagnostics done today and it turns out I’m having an issue with one of the EGR valves being stuck shut.
Was recommended to get them remapped (not sure what this means).
I asked if this is something I need to be getting fixed ASAP - but was told it’s not a big deal.
What should I be doing here?
Post #632906 Fri May 05 2023 11:40pm
If it's sticky, you may wish to try some Wyns EGR cleaner (fuel additive) ASAP
But, as you say it's not really urgent to replace the value itself.
May need to be done before MOT/Inspection. If ECU lights or fault codes will cause a failure
Post #632908 Sat May 06 2023 8:56am
NoExpert
I have a stupid question; how is a fuel additive supposed to have an effect on EGR’s? I would think anything beneficial would be consumed during combustion. It may help with the fuel system and injectors, but I just don’t see it benefitting anything post combustion.
Same with an intake cleaner, the EGR airflow is from the exhaust back into the intake, anything sprayed into the intake will be going through the combustion chamber before getting to the EGRs.
Somebody please educate me how either of these methods in fact clean the EGRs. Maybe some chemical compound can survive the combustion, I don’t know.
When I look up EGR cleaner manufacturer instructions they say remove the EGR(s) and physically clean them with the product. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #632911 Sat May 06 2023 12:25pm
I was similarly sceptical as you.
However the turbo vvt cleaner worked for myself and others. Which is a fuel additive.
So I’m not going to rule out egr cleaner.
Post #632913 Sat May 06 2023 1:50pm
riverblanche
had the same with one of my egr's and as Andy says its worth having a go with an egr cleaner just to see if it works, it is a chemical reaction that tries to clean the deposits/gunk,
the wynns I used was a spray you use in the inlet with the engine running not an ad to the fuel
think you will be delaying the inevitable and replacing them later though Question
mine was corrosion in the motor end when I replaced and stripped it
Regarding "remapping" from what I understand this is the wrong wording they Dont remap them but apply a "Patch" to fool the car to Not put the EML on Exclamation
if they only do this, its not a good way of doing things, Rolling Eyes
you really need to blank the egr's off (both) if this can be seen then it Should fail an MOT
so if blanked and pipes still in place it should be ok (for now MOT's change over time) you also need to remove the butterfly from inside the inlet manifold as well
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #632920 Sun May 07 2023 10:46am
