Home > Technical > RRS SDV6 3.0 Starts and Dies
nike_bytom
United Kingdom 2013 Range Rover Sport SDV6 HSE Java Black
Hi All,
RRS SDV6 3.0 2012 (2013 model) 110k miles
Car starts and dies, no error codes.
So far I have fitted new fuel filter - no luck still dies
Then I have measured pressure on Low pressure fuel pump using shredder valve on top of the engine engine and I am only getting around 2.5 psi (0.18bar) so I think this could be the issue? (Current measure ~6A while running). Also worth to mention I can barely hear the pump working (can hear it but I think is too quite if that make sense).
Any other components I can check before removing LPF pump? Question
Do I need remove tank to be able to swap pump or can I access from under the rear seats?
Do we know part number for the pump?
Thank you
Post #632509 Wed Apr 19 2023 7:07pm
Googs
Australia 2012 Range Rover Sport Supercharged Autobiography Fuji White
If you want to remove the fuel pump (fuel) you have to drop the tank there is no access under the seat.
Fuel pump= LR042717
Post #632763 Sat Apr 29 2023 8:21pm
nike_bytom
Thank you for replay, already replaced low pressure fuel pump last weekend still no luck... starts and dies.
Disconnected turbo hoses from intercooler same no luck, checked ecu for corrosion and water no issue there all fine, re-flashed ecu with lates software using sdd no luck. So next step will be to replace HPFP I think. Also I have discovered that my turbo is leaking oil very badly...
Post #632766 Sat Apr 29 2023 9:04pm
nike_bytom
Hi All
Removed HPFP from RRS what a job!
Now, can anyone recommend a good place for re-conditioned pump in the UK ? Or should I get a brand new pump?
Thank you in advance!
Post #632832 Tue May 02 2023 6:08pm
nike_bytom
After replacing HPFP still no luck, can not start engine.
So to summaries so far I have replaced:
1. Low pressure fuel pump
2. Fuel filter
3. High pressure Fuel Pump
4. Checked Relays for fuel pump and fuses
5. Fuel pressure sensor
6. Fuel rail pressure regulator
7. Connected external low pressure fuel pump directly to HPFP using fresh diesel
8. Disconnected dpf
9. Re-flashed tcm with SDD
And best is that there is no error codes! (SDD and Topdpn scanner)
Now, engine starts when engine 'start spray' is sprayed in to air inlet but dies when stop spraying.
Worth to add secondary? turbo (driver side UK) is covered in oil not sure if it failed or just return pipe failed.
The car was purchased for auction as non runner so it could be anything.
What would be next step I am losing this battle....
Check engine timing? Some kind of ghost type immobilizer fitted?
Please help Neutral
Regards
Post #633350 Wed May 24 2023 7:56pm
TheWojtek
My BMW used to do exactly that when the camshaft position sensor was faulty. No codes either. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #633353 Wed May 24 2023 8:51pm
nike_bytom
Thanks Wojtek, I think I will start first by replacing crankshaft sensor (it looks like common problem on those engines to fail with no code?) and if that not help I will go for camshaft sensor replacement.
Thanks again,
Pozdrawiam Rafal
Post #633359 Thu May 25 2023 12:15pm
TheWojtek
Cheers, powodzenia! Regards etc.,
Wojtek
Post #633362 Thu May 25 2023 6:54pm
RR-Panda
Australia 2012 Range Rover Sport 3.0 TDV6 HSE Lux Alaska White
Thanks again,
Pozdrawiam Rafal
Hi nike_bytom, Did you get this resolved? I have the same issue and have done much of what you mentioned to no avail, Cheers, Neil
Post #634767 Thu Aug 03 2023 1:52am
MickEng26
United Kingdom 2011 Range Rover Sport SDV6 HSE Bonatti Grey
Did ypu get to the bottom.of this ???
Post #646380 Sun Jan 19 2025 5:57pm
nike_bytom
Unfortunately I did not get this solved and sold the car 🥺 Regards Raf
Post #646386 Sun Jan 19 2025 9:13pm
