Home > Technical > Parking aid |
AMAC Member Since: 08 Nov 2021 Location: North East Posts: 3 |
All sorted now, removed bumper and belled out harness , was a dodgy wire to sensor |
Sun Apr 02 2023 10:35am |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 |
According to GAP tool my rear sensors are detected but fronts arent , can you tell me the sequence of belling out the harness , I get 12.5 n brown feed wire to plug behind the front headlight , earth is quite high resistance , do you also know where it might be sourcing its earth please .
Wed Apr 19 2023 4:45pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4813 |
I think the earth is from the ECU in the rear.
Wed Apr 19 2023 6:31pm |
I think I tried that , but will give it another go as I was trying to remove dipping mirrors when reversing in CCF and it said update failed. However that's resolved so will enter that sensor separation again.
Wed Apr 19 2023 7:17pm |
Ah ok , thanks will try that again , Thanks for your reply.
Wed Apr 19 2023 8:20pm |
So I have checked out resistances to each front sensors via the plug pins from behind the headlight (drivers ) , the results have not identified the culprit. All sensors have around 10ohms by probing between the main power feed (brown) to each colour associated to each sensor.
Fri Apr 21 2023 6:27pm |
Have you carried out a continuity check between pins on large plug behind headlight and pins on each sensor ? If you are showing high resistance between the earth pin on large plug and all 4 sensors pins that could be your issue . You could also try checking between earth pins on each sensor plug as they should be common . The faulty wire I found on mine had no visible signs of damage but very high resistance ( virtually open circuit . |
Fri Apr 21 2023 8:14pm |
OK , I read with interest on this one , I take it your asking to to check earth connections between sensor plugs back to male joint behind light.
Sat Apr 22 2023 7:58pm |
I have now checked continuity with all four front sensors and with each wire back to the plug at the rear of the headlight. They test out with no broken wires . Also checked wires back, earth, live , and four sensors to P module, they are all sound as a pound! Only thing left is sensors themselves. |
Fri Apr 28 2023 4:16pm |
Oh man , what a work for just one sensor! |
Fri Apr 28 2023 5:46pm |
A common fault is one of the 8 sensors having low resistance between the black and brown wires.
Fri Apr 28 2023 6:46pm |
First diagnostics threw me that no fronts were detected . So , that what was the route that there was a total failure , as you say both front and rears showed diagnostic failure . Having swapped the two fronts that I had access to without the bumper off and armed with three new sensors , the middle two were left. I could have saved some trouble by testing the middle two first once I had the bumper off, but hey ho the wiring is spot on ..... a red herring!
Fri Apr 28 2023 8:21pm |
