Home > Technical > will parts from the D3 fit the tdv8
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
So ive got the d3 to part out and im wondering which parts may be worth keeping.
im thinking
diffs front and rear
starter motor
alternator
wheels 19 inch 6 spoke, maybe anything else that may be used
Post #632529 Thu Apr 20 2023 7:24pm
TheWojtek
Audio, if better. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #632530 Thu Apr 20 2023 7:42pm
Disco_Mikey
Not much from a D3 fits a TDV8
Diffs and tranfer case should be the same if they are both diesel and Auto
Post #632549 Fri Apr 21 2023 7:36pm
monty19
Cheers, there both diesel and auto, thinking maybe the prop shaft would be the same, do you think the wheels may fit from the d3
Post #632557 Sat Apr 22 2023 6:26am
TheWojtek
The 19s do fit. Regards etc.,
Wojtek
Post #632592 Sat Apr 22 2023 8:21pm
Prop shaft won't fit - the Disco is several inches longer than the RRS and that length is in the prop shaft.
The rear drive shafts are different - the TDV8 has the stronger items used on vehicles with the locking rear diff. 2012 SDV6 - it's missing a couple of cylinders
Post #632593 Sat Apr 22 2023 8:21pm
monty19
Thanks guys
Post #632611 Sun Apr 23 2023 6:12am
