![]() | Home > Technical > HELP: RRS S/C Reduced Engine Performance. Stuck in France |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Yes. The DTC, available with any DTC reader, will tell you which bank it is, JLR equipment will tell more.
If we are talking spark plug separately, it's rather a high rpm + high load situation, which - accidentally - occurs at high speeds. If your engine temp was OK, the temperature will do nothing to spark plugs. In case of ignition coils, though, high temperature has a detrimental influence. If there was a direct problem with engine cooling, they would not work with (logical) steps of a spark plug and coil. How on Earth did an "indy" connect engine misfire with cooling is beyond me. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5079 ![]() ![]() ![]() |
I think you will find it is the s/c coolant pump not the fan that was wired incorrectly, the tsb does say a possible symptom is reduced engine performance and engine misfire, if I remember right.
Was this really originally posted back in 2012? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1890 ![]() ![]() |
He must still be there, he has not posted since starting this thread in 2012! |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1196 ![]() ![]() ![]() |
to be fair, he's better off than on Mud Island: actual food, good wine, and decent weather |
Damn, it showed right in my „new posts” list… Oh, busted! Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Yeah, strange showed up as a new post for some reason, never even looked at the date. |
