![]() | Home > Technical > trying to track down a water leak on a 5.0 SC advice |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 355 ![]() ![]() ![]() |
Blimey.........sorry to hear about this it's not good is it. |
drexal Member Since: 18 Dec 2019 Location: london Posts: 117 ![]() ![]() ![]() |
Update & hopefully the conclusion on the water leak for you all, hope this might help someone else.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
"And even though they found the oil cooler gasket to be the issue, they also replaced: rad overflow tank & cap-reservoir another £135 + labour. There answer for this was: there is a float in the overflow tank which, when the system is drained out, gets stuck. That would result in a coolant level warning on your dash if it hadn’t been replaced.
hi all,
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5133 ![]() ![]() ![]() |
try not to worry,
Thanks for quick response Andy, yea i will keep my fingers crossed, as prior to the repair the level would drop from the top level to bottom level in a 4 hour drive of a few hundred miles. It surely can't be a new leak as they changed every gasket, o ring and hose there is pretty much |
