![]() | Home > General > Low coolant |
Geodine Member Since: 08 Apr 2023 Location: Newcastle upon tyne Posts: 4 ![]() ![]() ![]() |
Hi just bought a 2013 L320 on Friday after a belt and service done on it. On Saturday the check low cooling display come on and red warning triangle. Pulled over and coolant level was above the max fill (as I would expect with expansion) and temp was bang in the middle. Started it this morning cold and everything ok but after driving 20 miles same warning. Left for 3 hours got in and no warning. Is this the classic sign for expansion sensor .?? |
karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309 ![]() ![]() ![]() |
dodgy sensor they get guncked up and stuck easy fix if your mechanical minded and good on the tools |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Yes, as above. I heard it was a bit of a fiddly fix so I got a new expansion chamber that came with a new sensor. Barrie.
Thanks for that. Got a warranty with it but need the car to go on holiday tomorrow for a couple of days. Only 30 miles away. Do you think it will be ok to use if I keep an eye on temperature
If that’s the problem, then yes it will be fine. Barrie.
Thanks for the help
Iomegas Member Since: 16 Nov 2020 Location: Newcastle Upon Tyne Posts: 217 ![]() ![]() ![]() |
Hi great to see another Owner from Newcastle on here as said dodgy float apparently they become saturated and sink.Its a relatively easy fix replacing the expansion tank I did mine a few months back.The bottom clip can be fiddly if you need a hand give me a shout glad to assist I have the tools the hose clamps and hose clip pliers . |
4x4 Garage near me replaced the expansion bottle with a new unit under warranty and all good now. Drove 260 miles to lakes and back and all good now. Thanks for all help |
You're welcome. Happy motoring! |
Glad it’s sortec m8 enjoy |
