![]() | Home > Maintenance & Modifications > Did any RRS1 have black headlining etc. as standard? |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 355 ![]() ![]() ![]() |
Hi Dean
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5151 ![]() ![]() ![]() |
The later facelift 2012/13 RRS1 did have the option of a black (ebony) headlining, not sure about earlier cars though or if there was any difference in the shape of the lining etc.
Dixie Dean Member Since: 05 Apr 2023 Location: Halewood Posts: 8 ![]() |
Cheers Col. I think you are probably correct, although not many made. I've been searching to find out whether anyone is dismantling one from which I could get the sunvisors or grab handles from. |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 517 ![]() ![]() ![]() |
We have a Kahn at the shop with all black interior, including headlining, etc. so they’re out there. I think it’s a 2013.
They were only a option from vin no. CA000001 on and as normal with L/R there were 16 different ones listed although probably not a lot off differences, but depending on with or without sunroof, which sound system etc. etc. finding the plastic bits might not be to bad, but finding a s/hand headlining without to many cut out's might be a bit more of a challenge.
Crraigymmmmm Member Since: 06 May 2021 Location: Peterborough Posts: 163 ![]() ![]() ![]() |
I struggled to find a black set so I dyed mine, wasnt too bad,
Can you suggest any sites it would be worth trying. And what would be the search terms for Sunvisor and Grab Handle? @Col I don't need a headlining as that is being totally recovered with black fabric. @Crraigymmmmm what dye did you use? Which model year Focus were the grab handles out of? |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 750 ![]() ![]() ![]() |
Here, sunroof: https://www.otomoto.pl/oferta/podsufitka-c...FocWV.html
Ficus mk2 matey. About £20 for a set |
@TheWojtek Thanks I have sent them an email.
