Home > Maintenance & Modifications > Disc painting Advice
5.0 ltr Frank
Will the Grey coating on the Original Disc last if I applied a High Temperature lacquer or will it simply burn off ?
Advice would be much appreciated Bow down
[img:533:400]https://www.rrsport.co.uk/gallery/albums/userpics/30911/normal_2023040
1_134655.jpg[/img]
Post #632058 Sat Apr 01 2023 1:58pm
TheWojtek
It will eventually start to disappear, although what is the most important bit is the preparation of the disc before painting. They are covered with stuff that needs several sessions with rubbing alcohol to get rid of it, and only then it does make sense to paint. A good high-temp paint will obviously last longer. Do not get tempted with too many layers, though, after the 3rd-4th layer the subsequent will not make the coating last any longer. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #632064 Sat Apr 01 2023 5:07pm
5.0 ltr Frank
I am in the process of cleaning / preparing the discs to apply a Clear Laquer ( ordering Monday)
I like the idea of keeping them looking fresh for as long as possible.
Thanks for your advice Thumbs Up
Post #632065 Sat Apr 01 2023 5:27pm
I have used this in the past, personally found it excellent and lasted well, as said preparation is the key.
https://www.demon-tweeks.com/uk/foliatec-b...er-243118/
Post #632078 Sat Apr 01 2023 10:45pm
5.0 ltr Frank
^ i was going to order this...( any experience of )
https://www.ebay.co.uk/itm/353814745169
i like the idea of retaining the "Original Grey New Look" for as long as possible, if possible. i appreciate the Grey will highlight brake dust, but I'm pretty keen in the keeping everything clean department so...
regds Frank
Post #632085 Sun Apr 02 2023 9:59am
I also used the VHT stuff when I replaced the discs on my s/c as options are bit limited down here, it is holding up really well for a couple or so years now used it on the rear calipers as well as the original red finish on the factory calipers was crap, but do have the added advantage that they don't use salt on the roads here.
Post #632086 Sun Apr 02 2023 10:09am
5.0 ltr Frank
^ You've convinced me...... I'm on it. Thumbs Up
Many thanks Bow down
Post #632087 Sun Apr 02 2023 10:13am
5.0 ltr Frank
Post #632215 Sun Apr 09 2023 3:56pm
