Home > General > 3.6 TDV8 - Front and rear disc replacement - Meyle
Jabba
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Good morning,
I'm looking at replacing the front and rear discs and pads on my 2010 3.6 RRS. I've found that AF can supply a kit by Meyle, has anyone used these and what are peoples thoughts.
I had read that Brembo are recommended but, I've only found one supplier on ebay and they only supply drilled discs for my model as a kit.
Many thanks
Craig 2010 RRS 3.6 TDV8 HSE Galway Green
Post #631937 Tue Mar 28 2023 8:27am
Pufftmw
Never heard of Meyle so can't comment but I use https://www.godspeedbrakes.co.uk They do discs/pads for motorsport uses but also provide for "fast road" for any other vehicle. I currently have their grooved discs/matching pads on my RRS and whilst a Brembo equipped RRS is not short on stopping power, these add an extra level of comfort and ability. Just waiting for the front discs on my XC70 to wear a bit more and I'll be going there for those too.
Post #631939 Tue Mar 28 2023 9:24am
gogsy1956
I don't think you can go wrong with Meyle parts,, they do a good range of parts for suspension etc and while not being the most expensive they are certainly better than the cheap options they even have heavy duty options for some drop links and the likes I believe. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #631961 Tue Mar 28 2023 8:27pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Yep my go to brake discs I fitted AFs V8 disc conversion to our D3 they are very good quality.
Post #631964 Tue Mar 28 2023 9:38pm
Jabba
Many thanks for your replies guys, much appreciated 2010 RRS 3.6 TDV8 HSE Galway Green
Post #631967 Wed Mar 29 2023 6:04am
Dave-t
have you tried Euro car parts and German and Swedish, both do Brembos (for L494 at least) at reasonable prices with the right codes. Joined the X5 45e club
1994 Defender 90 300 tdi
Post #631974 Wed Mar 29 2023 12:26pm
Meyle have a handy online catalogue of their parts too, with options for things like pads. Perhaps worth a look at if you're interested.
https://www.meyle.com/en/service-centre/online-catalogue/
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #631977 Wed Mar 29 2023 5:17pm
Lrstaylor
The ECP brembo discs are rebranded chinease crap.
Post #631985 Wed Mar 29 2023 8:42pm
I'd be surprised if Brembo put up with that. Or do you mean that they're branded ECP and come from China? 2012 SDV6 - it's missing a couple of cylinders
Post #631986 Wed Mar 29 2023 9:15pm
If anyone goes onto Brembo's own web site looking for discs/pads etc. they have a listing for their aftermarket discs, if you want to click on it, it actually takes you to a Chinese web site for the discs, so I assume even Brembo's own aftermarket discs are made in China. They do not list drilled/vented discs for the Sport either, so rightly or wrongly I suspect some firms have simply taken the discs to a machine shop and had them machined with grooves and drilled put them back in the original brembo supplied box and pass them off as original drilled and grooved Brembo's.
Post #631988 Wed Mar 29 2023 10:11pm
Jabba
To be honest I'd be happy with just standard discs, not drilled and grooved. 2010 RRS 3.6 TDV8 HSE Galway Green
Post #631992 Thu Mar 30 2023 6:13am
I once ran drilled discs on a hot hatch that I used to thrash around the place (I was young and stupid, ok!). They made 3/5ths of Censored all difference unless I really, really tried. I doubt they'd make any difference at all on an RRS unless it is being driven by someone looking for a DWDCA penalty...even the SVR has solid discs - they're just bigger. 2012 SDV6 - it's missing a couple of cylinders
Post #632004 Thu Mar 30 2023 11:29am
Jabba
The previous owner of my D2 TD5 installed drilled and grooved discs even though he only drove it on the road. I must admit they've lasted well as I've owned it for the last 10 years. 2010 RRS 3.6 TDV8 HSE Galway Green
Post #632006 Thu Mar 30 2023 11:35am
Drilled and grooved discs wouldn't be much use off road, I'd guess. Imagine the grooves / holes filling up with grit / stones and then getting dragged in to the pads. Recipe for a very short, and squeaky, brake life. 2012 SDV6 - it's missing a couple of cylinders
Post #632008 Thu Mar 30 2023 12:13pm
Jabba
The only time it goes off road is when it's on the drive or in the garage Very Happy 2010 RRS 3.6 TDV8 HSE Galway Green
Post #632009 Thu Mar 30 2023 12:36pm
