Home > Technical > ZF8 Transmission Problem Help Please
5.0 ltr Frank
My ZF8 Transmission Only when cold is slow to change up, slight hesitation 2nd to 3rd, seems to linger longer in 2nd before changing up. Once this initial change has occurred there's No other problems at all, works absolutely fine. No error lights on the dash. I've had the oil and filter pan changed, genuine LR parts, but still have the same problem.
any help / advice would be greatly appreciated. Bow down
Post #631945 Tue Mar 28 2023 11:45am
Dave-t
What's the age and mileage?
A gearbox flush is well recommended for these, by around 75-80k ish, although LR say its not needed until something like 160K. Joined the X5 45e club
1994 Defender 90 300 tdi
Post #631946 Tue Mar 28 2023 12:14pm
5.0 ltr Frank
it's 2016 and 60500. i had it done as preventative measure.
it's just the initial move off when cold
Post #631947 Tue Mar 28 2023 12:28pm
Stevepd
As it's only when cold it could be the cars way of warming the oil to temperature. Also these things are discussion worthy about getting off the line. If it were me I would think much about it, especially as you've done a oil change. If it was juddering etc I'd be giving it more thought. Others will respond shortly though. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #631952 Tue Mar 28 2023 1:23pm
5.0 ltr Frank
^ Thank you Bow down it is only when it's cold.
Post #631953 Tue Mar 28 2023 1:30pm
djpgowrie
FWIW i agree with this - my 6 speed box holds all gears a little longer when cold. its almost as if it wants higher revs to get to operating temp quicker
Post #631955 Tue Mar 28 2023 2:25pm
5.0 ltr Frank
^ Thank You Bow down
Post #631956 Tue Mar 28 2023 2:32pm
TheWojtek
Same here, when cold, my 6HP holds the gears up to 2000 rpm. It was like this before megaflush, it's the same after megaflush. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #631957 Tue Mar 28 2023 2:32pm
5.0 ltr Frank
Post #631958 Tue Mar 28 2023 2:38pm
It is designed to do this, as you say, in order to help speed up the warming process - to help emissions more than anything else. 2012 SDV6 - it's missing a couple of cylinders
Post #631959 Tue Mar 28 2023 3:31pm
5.0 ltr Frank
^ Thumbs Up
Post #631960 Tue Mar 28 2023 3:41pm
