Home > Technical > Crazy Hot Rear Brake |
djpgowrie Member Since: 04 Jun 2020 Location: Manchester Posts: 40 |
I've read through this post: https://www.rrsport.co.uk/forum/post486827.html#486827, which has all my symptoms but no answers have helped me.
Mon Mar 27 2023 10:08pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 431 |
Seized EPB cable? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Tue Mar 28 2023 2:57am |
There seemed to be good play in the cable when I replaced the EPB shoes, and I can hear the actuator working. Is there a method I can check a seized cable for sure? |
Tue Mar 28 2023 6:29am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4804 |
Just replace the callipers.
Tue Mar 28 2023 7:50am |
Just reread and saw wheel, not drum. Sorry. I’d say seized caliper as @Andy K mentioned. Sometimes they can be rebuilt, sometimes they can’t. What rebuild kits did you use? I used FrenKit on my fronts and rears and they seem to be okay. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Tue Mar 28 2023 10:21am |
Been thinking more into what you said about EPB seizing and there may be something there. 12-18 months ago there was a period of time whereby releasing the parking brake it sometimes didn't fully disengage (even with the actuator sound). the wheel in question would stick and then on pulling away suddenly give way with a loud clunk. Naively i thought nothing of it at the time as there was no errors or warning lights (wishful thinking and just plain ignoring the obvious need for investigation).
Tue Mar 28 2023 11:34am |
As long as you don’t accidentally hit the EPB switch it may be worth the trouble of trying that. Just keep the cable tied away from anything moving. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Tue Mar 28 2023 12:51pm |
A caliper is ~£50 and doesn't take long to fit and bleed.
Tue Mar 28 2023 12:59pm |
Completely get your point but I'm reluctant to keep throwing money at it before knowing for sure. Especially when I've already done a complete overhaul already, assuming it's one thing or another.
Tue Mar 28 2023 1:05pm |
Ok so I'm now going down the line of bad EPB cables or actuator based off these videos:
Tue Mar 28 2023 9:16pm |
My feelings are my time is free, parts cost money. I’d rather spend a day diagnosing and troubleshooting than waste money on parts I don’t need. So I’d say diagnose it out and replace what’s in fact the problem. It’s always so easy to spend other people’s money on the internet. Sadly I get to see more of it in person where somebody said xyz is the problem and they replaced it at a high cost only to find out it’s something totally different and a cheap fix compared to the big money they spent on some random part. Like the guy who had his transmission rebuilt when he needed his alternator replaced. Yes, that really happened. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Mar 29 2023 7:39am |
Yeah that's my line of thought too. I didn't mind the cost of caliper rebuild and new discs/pads/shoes because they're consumables anyway and will have needed doing at some point soon anyway.
Wed Mar 29 2023 8:16am |
It’s quite likely based on what you’re describing. I had a sticking lever on an EPB shoe, chewed up the drum, got pretty hot, etc. it would be similar if you have a sticking cable. Trouble will be getting a replacement cable, not impossible of course, but will likely be Chinese or second hand. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Mar 29 2023 10:10am |
Thanks mate, it appears you can get them pretty easily:
Wed Mar 29 2023 11:08am |
