![]() | Home > Technical > Service Kits - Any Advice Regarding Supplier/Manufacturer |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4483 ![]() ![]() ![]() |
The Britpart kits are fine (we use them on a daily basis in the workshop) but make sure you get the OEM version, and use a good quality 5W30 oil |
skid1963 Member Since: 24 Mar 2018 Location: Snodland Posts: 218 ![]() ![]() ![]() |
That's the problem DM....there is so much choice regarding the oils, the kit i'm looking at has Rock oil, other kits have Miller oil or QX or Castrol....if they all match the spec required whats the difference?? 2015 L494 SDV6 3.0 HSE Loire Blue
Out of those, I'd go for Castrol |
Thanks Mikey......bloody minefield oil choice |
Used to use Shell oils, then we moved to Comma |
Ok.....seen a kit with Comma oil, what about Mannol, any good?
Apparently...
Thanks for the advice Mikey
That's not an OEM kit... |
I just cross checked the part numbers of the one you recommended above and the one i ordered,
DA6037P isn't what you've linked to.
yup.....asked them to cancel order and i'll order the OEM kit 2015 L494 SDV6 3.0 HSE Loire Blue
