Home > General (L494) > Running boards removal and repair
Phil23
United Kingdom 2013 Range Rover Sport SDV6 HSE Java Black
Morning All. 2013 L494. The plastic trim on my running boards is coming adrift. Is there an "idiots guide" to the removal and replacement?. I want to clean them up, treat the rust and paint them, and repair the broken rivets.
Phil.
Post #631853 Thu Mar 23 2023 9:10am
Lindab
I did mine recently, easy. Put car up to max height. From memory there are 3 brackets supporting the steps. Do not remove the brackets. Just remove the steps from the brackets (either 3 or 6 screws. Take it easy as they will be rusted. Give the steps a pull & they are off. Front edge is a bit harder, think I opened the door slightly to help, but no drama. My side finishers were fine unlike yours. Lots of rust, comes off easy enough. I put on rust preventative then some really decent enamel type paint. Thumbs Up Range Rover Sport (gone): Mercedes S63 AMG Coupe: 992 Porsche Carrera 4S: Range Rover Fifty P400e
Post #631854 Thu Mar 23 2023 9:27am
Red Arrow
Re: Running boards removal and repair
Phil.
I have a brand new set of brackets if you want them while you are doing the steps Thumbs Up
Drop me a PM - Also I am in Scotland
Post #631864 Fri Mar 24 2023 12:16am
Phil23
I may well need them. Hoping to do it next week so will be in touch if I do. Cheers.
Post #631874 Fri Mar 24 2023 12:46pm
karlos01
done the same on my l320 just take the side steps off
get a piece of wood and some good clamps
dob a bit of stick like Censored to the trim clamp in place then drill a hole and rivet back in place I left mime for 24 hours before putting back on the rr
Post #631886 Fri Mar 24 2023 6:55pm
