Home > General > transmission oil & filter at service or flush
drexal
United Kingdom 2012 Range Rover Sport Supercharged HSE Santorini Black
Hi guys,
Been a while since i have been on here which is a good sign i guess, that i've not had any issues.
But i had a question i was hoping someone could help me with.
I've got my 150,000 mile / 10 year service, its a big one. I've attached the LR service list. LR are quoting over 2k. Which i can't afford, so i'm getting quotes from different independent specialists.
But i'm having some conflicting advice from different independents.
Regarding the transmission oil & filter, one indy is saying you're much better off having a flush and leaving the filter in place.
(the price is similar for the flush is similar to oil and filter change though)
And the other indy is saying we advise, if your transmission is fine and your not having any issues, do not change transmission oil and filter and do not flush and just leave it alone, its sealed for life.
I have read both these forums, most people are saying do a flush, but there are conflicting opinions in these forums too.
https://www.rrsport.co.uk/forum/topic57365...oil+change
https://www.rrsport.co.uk/forum/topic54164...oil+change
Also regarding the “Replacement of Dynamic Response valve block filter & top up system” they are saying if these filters are changed is can cause pressure issues within the ACE valve block itself.
And other indy is saying, maybe just change the fluid and just check if the filters are dirty.
So a little confused on what to do. My RRS is a 2012 5.0lt SC and has only done 70k it has had main dealer service history its whole life and since i bought it 3 years ago, its has main dealer and indy specialists so i have followed all the correct services plans each year. So would like to keep servicing to LRs recommendations.
Any advice would be hugely appreciated. 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #622042 Fri Feb 18 2022 10:48pm
riverblanche
regarding "sealed for life" Censored think that is L/R's responsibility life and not the gearboxes life Rolling Eyes
does the same indep not change the engine oil if the engines running fine as well Shocked
preventative maintenance oil changes are worth doing a flush is a Transfusion so maybe more oil changed than when a filter change done.
dont know about the ACE but can not see the logic of replacing the oil and just checking the filter Exclamation gone that far change it anyway
think I would be asking other indep Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #622054 Sat Feb 19 2022 3:49pm
Scrumpy
I looked into the gearbox flush myself and in the end I went for the service, including oil and filter.
The reasoning I did this on my 125k miles 2005 4.2 SC were because of my Indy's advice and after reading his blog;
https://glenrands.co.uk/2021/03/28/know-yo...dont-need/
hope that helps 2016 RRS SVR Estoril Blue
Post #622057 Sat Feb 19 2022 4:16pm
Stevepd
at 70k I’d just do a flush. I’d steer clear of the indie that says don’t bother it’s sealed for live. I had mine done a couple of years ago. Whilst it was the oldest car of the day it was the lowest mileage. My oil was the blackest. I had no gearbox issues and was purely preventative.
https://www.rrsport.co.uk/forum/topic53094.html?highlight=flush 2006 2.7 TDV6 HSE in Cairns Blue.
Post #622059 Sat Feb 19 2022 5:38pm
Kot
hope that helps
That's good information in the blog, I guess you can lead an horse to water! but Rolling with laughter
Post #622061 Sat Feb 19 2022 7:09pm
Disco_Mikey
hope that helps
Quote:
As long as your transmission fluid is replaced in accordance with the schedule in your owner’s manual, you’re giving your transmission all the maintenance that it needs.
That's funny. My own gearbox packed up at 132k, before it was even due an oil change...
Post #622062 Sat Feb 19 2022 11:12pm
drexal
Thanks for all the help and advice guys, really appreciated Thumbs Up 2012 RRS HSE 5.0 SUPERCHARGED Santorini Black
Post #622082 Sun Feb 20 2022 3:51pm
LesW
France
The advice from the manufacturers, ZF, is to change the trans oil at around 60k, so anyone saying sealed for life is plain wrong. A Cheshire expat in France.
2015 RRS HSE 3.0 SDV6
2015 Aston Martin Vanquish
2010 Jaguar XFR Le Mans
Post #622085 Sun Feb 20 2022 4:40pm
DrRob
Take it to Dartford Transmissions and Autocare for the gearbox service. Experts. Visitor from fullfatrr.com
Post #622107 Mon Feb 21 2022 10:16am
DirtBuddha
England 2010 Range Rover Sport TDV8 HSE Galway Green
My view is that you should do both, not one or other.. i.e. why would you do a 'megaflush' without filter change?
I know many people do, but it beats me why you'd go to the trouble of doing a full megaflush without changing the filter.
Post #622114 Mon Feb 21 2022 12:38pm
Amir
United Kingdom 2013 Range Rover Sport SDV6 HSE Java Black
I agree so why do people seem to choose one or the other?
Post #627567 Sat Oct 22 2022 2:02am
The filter isn't that important. The oil is. Simple really. 2012 SDV6 - it's missing a couple of cylinders
Post #627568 Sat Oct 22 2022 2:05am
DrRob
IIRC it's not really a "filter" as per oil/air type. More of a strainer....
I had a Megaflush, but no filter at 80K on my L322. No issues before, no issues after.
ZF say change it, so change it. LR got it wrong IMHO.
Use Bodsy on your driveway for convenience Thumbs Up Visitor from fullfatrr.com
Post #627633 Tue Oct 25 2022 8:17am
My SDV6 (which I bought from DrRob above) had its second flush at the recent service. It's on 136k miles and was previously done around 70k miles.
It costs no more than doing the filter and changing a bit of the oil (the LR technique doesn't change all of the oil, the flush does) and means you have a gearbox filled with fresh oil containing all of the nice additives that are the important part of the oil change 2012 SDV6 - it's missing a couple of cylinders
Post #627635 Tue Oct 25 2022 9:24am
Amir
Anyone know anywhere that does a flush around liverpool?
Post #631816 Tue Mar 21 2023 4:47am
