![]() | Home > Maintenance & Modifications > Suspension confusion.. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
So with fuse removed, right front dropping ?
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 432 ![]() ![]() |
Thanks Andy - yep, front right dropping this time and pretty quickly. Typically the tab on the electrical connector broke off and I didn’t realise, so having stripped everything and put it back together I was getting a suspension fault. Stripped down again to find the connector hanging loose.
If a tiny seal falls out the valve block, it will blow the connector off. Even with a good tab.
Not sure I’m understanding that correctly Andy - surely the electrical connector and pressurised side aren’t connected ?
Connector shouldn’t be pressurised. But as said. If a seal is lost it can be! Ask me how I know!
New world record for stripping and rebuilding everything, including stripping down the valve block !
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 352 ![]() ![]() ![]() |
Well done that man ..... |
Not so fast sunshine ! (as my dad used to say..)
Oh yeah. Sounds like middle valve block
It’s front right dropping - used to be front left.
I guess you need to put soapy water around the valve block and pipe connector and may as well do front strut. (while it has air in the system!) see if it has bubbles.
The packing silicagel would get rid of the issue of degradation, but not sure it would have the same drying ability. |
And another update...
More updates - front valve block rebuilt and installed (twice).
