Home > Technical > Ghosts in wing mirrors
BigBerthaTheRRS
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Hi all,
Weird issues that seems to be getting worse. Firstly, the drivers (right) mirror started to turn inwards and down while driving. At first I thought the mirror was loose but found that if I push the mirror back when stationary it tilts back again. It doesn’t do this with the ignition off. It then got more strange. Both mirrors can only be adjusted downwards and to the left. The ‘up’ control sends them down and the ‘right control’ sends them left. This happened progressively.
Have googled extensively but can’t see anything. Any thoughts?
Cheers 2005 2.7 tdv6 RRS Vin 6A
Post #631372 Sun Mar 05 2023 5:07pm
Crs
England 2013 Range Rover Sport Supercharged Autobiography Firenze Red
Sounds like it’s going into the reveres position
Post #631395 Mon Mar 06 2023 8:37am
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Had this problem with mine when I first purchased it , I found out through the manual that it was for reversing managed to cancel it completely by instructions in the manual/handbook had no problems since.
Post #631406 Mon Mar 06 2023 5:53pm
BigBerthaTheRRS
Thanks for the suggestion, both. I just don't get why it does this at random points during driving and I can't control the wingmirrors right and upwards on both sides. Reverse parking mirror setting was already turned off too it seems. 2005 2.7 tdv6 RRS Vin 6A
Post #631468 Wed Mar 08 2023 2:17pm
BigBerthaTheRRS
Fixed! I noticed passenger seat electrics weren’t working. Also found it difficult to get key out of the ignition. All pointed to F33. Should have noticed this sooner but strange to me how the mirrors semi work even with a blown fuse.
Post #631578 Sun Mar 12 2023 11:33am
BJH1959
Portugal 2005 Range Rover Sport TDV6 HSE Cairns Blue
Thanks for posting the fix! Thumbs Up Barrie.
2017-Jan 2024: 2005 RRS 2.7TDV6. Best car I ever had - until now!
Current: 2018 Ford Ranger Wildtrak 3.2
Post #631579 Sun Mar 12 2023 12:57pm
Boxers
That's great always pleased when a problem is sorted.
Post #631581 Sun Mar 12 2023 2:54pm
Brian Considine
My door mirrors have the same issue & I cannot switch off the reverse feature (or can't seem to) as the previous owner replaced the standard head unit with a touch screen one (that I hate with a passion) - not only was the job poor (original HK amp by-passed & no steering wheel controls) I seem to have lost many on-board computer features.
I'll have a look at F33.
Post #631584 Sun Mar 12 2023 4:45pm
If you have a GAP IID you maybe able to turn it off ?
Post #631585 Sun Mar 12 2023 5:09pm
BigBerthaTheRRS
Following up on this thread with the weirdest solution. I noticed that the key would occasionally get stuck in when I stopped the vehicle which can be linked to transmission apparently. Then I noticed passenger seat wasn't working. Turned out a single fuse links 'transmission', 'passenger seat adjustment' and 'wing mirrors'. Strange that 1) these are all on one fuse and 2) that with a broken fuse, the mirrors didn't just die, they got a life of their own. One of the oddest things I've seen!! 2005 2.7 tdv6 RRS Vin 6A
Post #641282 Fri Apr 19 2024 11:13am
