Home > Faults & Fixes > Suspension
TommyM
United Kingdom 2007 Range Rover Sport TDV8 HSE Zambezi Silver
Suspension
Know range rover has gremlins etc my 2007 rrs tdv8 has compressor replaced, now when sitting for a period running or when driving 4x4 screen shows ns front wheel rising and os wheel dropping sorts itself out after a few minutes, then repeats after a while, suspect height sensors or valve blocks any thoughts guys(uk based)
Post #631462 Wed Mar 08 2023 9:29am
JonnyCJ
An easy fix/elimination is rebuilding the valve blocks. £18 for a new seal kit on eBay and how to videos on YouTube courtesy of Hazy.
Post #631516 Thu Mar 09 2023 9:07pm
TommyM
Thanxs Jonny, will have to get new valve blocks, hand problem means can't do refurb, live in Belfast can easily get reservoir block and front block rear block seems to be an issue
Post #631536 Fri Mar 10 2023 6:53pm
JonnyCJ
I’ve just bought a used front valve block and 3 block seal kit - £27 for the lot. Going to do all mine just because it’s a simple preventative bit of maintenance.
Post #631537 Fri Mar 10 2023 7:13pm
TommyM
I know I can get them but everyone I put in rear valve block, it looks the same as front block
Post #631538 Fri Mar 10 2023 7:21pm
JonnyCJ
Want me to send you a rebuilt front ? Will do it at cost.
Post #631542 Fri Mar 10 2023 8:43pm
TommyM
Can u give me cost m8 but hang fire till I speak to garage
Post #631543 Fri Mar 10 2023 8:50pm
JonnyCJ
Probably about £35 posted
Post #631544 Fri Mar 10 2023 8:56pm
TommyM
OK m8 will get back to u as soon as i can just need to confirm that is actual fault although I agree with you about it
Post #631545 Fri Mar 10 2023 9:11pm
