![]() | Home > Maintenance & Modifications > Soft close doors |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 427 ![]() ![]() ![]() |
I think the door closure on Range Rovers is particularly sensitive to the striker ajustment. My front passenger door is easy to close, whereas the drivers door always requires several attempt to close (or use more force) if all other doors are closed, but is easy to close when one of the other doors or the rear hatch is open. I have ajusted the strikers on all doors so that dors and the body work are flush. You may find that the drivers door needs adjusting slightly outwards, but you may find that the panels are not flush when you adjust so that it closes easily. |
Crs Member Since: 04 Sep 2022 Location: Hampshire Posts: 82 ![]() ![]() ![]() |
Land Rover and doors, good to know they are keeping up the tradition of doors not shutting properly, my Discovery seems to be the exception but my Defender drivers door is suicidal. |
