![]() | Home > In Car Electronics > GPS disk? |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Updates for pre-facelift satnav ended in 2013. They included just the maps anyway, no additional system functionality. Regards etc.,
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 341 ![]() ![]() ![]() |
Thanks for the info!! So are we thinking if I can obtain a disk pre 2013 I will get the other facilities such as "make notes" and other features?!? Andrew Kennedy |
I am afraid you'd have to update the firmware in the DVD drive, not the maps themselves (which is what comes on the disc).
Thank you for the advice! I would rathe use the paddle for the features it offers. So I wouldn't mind updating the firewall but I wouldn't know how to start to the download - advice would be gratefully received. Andrew Kennedy |
I have tried to find the answer on line as to how one updates the firewall on my DVD drive....but haven't found useful info. I live in the country side of France and don't stand much of a chance of anyone here knowing the answer. If you know the path I should take - I would appreciate your advice. Andrew Kennedy |
Well, it would take searching for "firmware" and not "firewall" first.
That's an interesting observation! So are we thinking the DVD Disk has nothing to do with the facilities the paddle offers?!? If that is the case, is it a computer fault? The overall condition of the vechiel is in extremely good (83,000 miles on the clock). I have had it from new and would like to keep all the features in working order. If you have any further thoughts and advice I would be please to hear from you,,,, Andrew Kennedy |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5083 ![]() ![]() ![]() |
Well I never knew about voice notes!
Hang on Andy...not to technical please. What is an ECU unit? Are you of the opinion that the commands from the paddle are not in any way do to with the GPS Disk? if so any thoughts as to how I can get the paddle to do what it is supposed to do. Andrew Kennedy |
An ECU is "Engine Control Unit". Obviously a wrong use of the abbreviation, as Andy probably meant "computer".
I'm not sure the voice control is the same unit as the satnav, but may be wrong. Never used voice control anyway, it's beyond comically unable to perform in times of Siri or Alexa. Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5088 ![]() ![]() ![]() |
If Voice Control is the same thing as the "Voice Recognition" system then the software is in the navigation computer.
As far as I know it was about engine, but then again English is not my first language and even Wikipedia is ambiguous.
I think you are right if the voice recognition feature can be updated, it is nothing to do with using the latest navigation disc, it is the software/firmware that needs updating in the actual computer as I'm assuming there is some sort of hard drive in there, that is assuming there is even a update available, may be how this is screenshot is interpreted which it is, however as you say after 20 odd years I doubt it.
savi18 Member Since: 02 Aug 2015 Location: Gore. South Island NZ Posts: 154 ![]() ![]() |
My 2009 RRS is only a S model and does have the voice control. |
