![]() | Home > General > 6 Pot Brembo v 6 Pot Land Rover Callipers |
Still made by Brembo as far as i was aware, and that Land Rover didnt want to pay Brembo the fee to use their name on them. So my guess would be that Land Rover used their name on them instead. |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 253 ![]() ![]() ![]() |
Reason i ask is because i have a set amount of Brembos that are been exchanged for refurbished and it looks like they have the Land Rover ones to exchange Not the same and wondered if its a good idea or not, I could get the Brembos refurbished but this would be a longer turn around? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5150 ![]() ![]() ![]() |
I think you will find they are the same calliper. L/R ones just plain grey with Range Rover on them, Brembo's painted red with a Brembo sticker on them, probably for the reasons Buckster suggested, red callipers were also a nco on the S/C.
OllieSD Member Since: 20 Feb 2023 Location: Watford Posts: 24 ![]() ![]() |
Lovely setup that |
Thanks Ollie, Wasnt Sure if the red was abit much was debating having Black Callipers but i dont think it looks too chavvy 😀 They do draw the attention straight to the front brakes though with all the Motor been black. |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 256 ![]() ![]() |
The 6-pot calipers that I purchased were originally red but then, someone had redone them with a brush and the Brembo sticker wasn’t great quality and had buckled in the heat. I had them refurbished in black with white heat-proof lettering.
I wasnt sure if my disc was on the right side? |
The wheel is the left hand side front. The disks are Britpart and are fitted correctly. I can’t remember whether it is Porsche or Aston Martin who fit them the other way around. |
Same as mine, I wasnt sure and couldn’t find a straight answer so took a guess, Im not sure about the back ones either but apparently it doesnt make a big difference but still nice to know they’re correct. |
Back disks should be fitted in the same orientation as the fronts according to Britpart! |
Great i will check tomorrow although i dont fancy taking them of messing with the shoes, They’re Terrafirma discs aswell not britpart but im guessing the science works the same way. |
I had a set of Britpart discs with low dust pads on my last sport & was very happy with them.
My front drivers side hs started squeaking when braking, Not at first when cold but after a few miles, New discs and ebc yellowstuff pads, Not a loud squeaking but annoying one, Im just hoping its a bedding in noise and not one of the pistons sticking on the refurbished 6 pots i just got also. |
