![]() | Home > Faults & Fixes > L494 gearbox fault |
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 331 |
Would it not go into gear or was it showing the terrain response gear error? |
| Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436
it showed the D on the dash but came up gearbox fault and wouldn't move. Switched off and restarted a couple of times and it worked fine and changed as it should. Will try and read codes later Joined the X5 45e club
| Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595
I dont think the shifter fault shows up as a fault code . (didnt show when ours failed ) Its an easy job to do |
I had a P1707 code which can often be caused by low voltage. I had done a few short journeys and it cleared after the car was running for a few minutes so seems to make sense. Joined the X5 45e club
| All times are GMT |
