![]() | Home > General > Hello and a quick question |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9090 ![]() ![]() ![]() |
I don't think there was such a thing as a TDV8 Autobiography, or, if there was it was a fairly short-lived run-out version. The TDV8 was HSE with its own trim level above the other diesel HSE. Sunroofs were optional (my 08MY TDV8 HSE didn't have a sunroof). 2012 SDV6 - it's missing a couple of cylinders
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5096 ![]() ![]() ![]() |
Sunroofs were a optional extra on all variants, including the Autobiography.
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
Thanks for your replies, its answered my question.
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1903 ![]() ![]() |
A lot of HSE models with modified by owners by adding the Autobiography grill, etc. 2023 P440e SE Dynamic on order -cancelled
Ask to see the V5/Logbook if it is a genuine Autobiography it will say AB where the model is, not the A at the end that just means Auto.
I had another look and it appears that the last 6 months or so of TDV8 run was available as Autobiography. Not sure what they got over the previous TDV8s, however, as the TDV8 was always well spec'd. ![]() It's worth remembering that people do modify lesser models by putting the AB front end on them and then call them AB. You'd need to see the V5 to confirm. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
I don't know about the MY10 cars but my A/B has Autobiography Sport embossed in the front headrests, it's also on the front and rear door card trims as well as the door finisher treadplates, in addition to two tone interior which was standard in the A/B although it is a MY13 car. I think some of the MY10 cars maybe be referred to as Autobiography LE as there was originally only going to be a limited number, but L/R decided to continue production and dropped the LE bit.
A few logos isn't a deal breaker, however. It's the added kit is why one would buy an AB over a HSE. At least, for me it would be. The TDV8 had things like adaptive cruise as standard so most of the difference is going to be logos and body kit. 2012 SDV6 - it's missing a couple of cylinders
I'm pointing out some of the obvious noticable differences between a standard HSE and the A/B so the OP has some idea what he's looking at if he is being told it is A/B but actually a old HSE tarted up to look like a A/B as I can't imagine anyone changing trim, door panels etc. to make it look like one, as for the acc personally never use mine as consider it a complete waste of time.
I'm not sure the early move to AB had all of those logos and embossed details. Probably wrong though. |
I've just checked in the James Taylor book about the sports, the TDV8 Autobiography's were only made from January 2010. I guess until they ran the 3.6 models out on the sports |
