Home > Maintenance & Modifications > The cars telling me Suspension and battery issues
Stevepd
Hi all, I've noticed a couple of times now the OSF upper white line flashes red on the first start of the day. The car rises and lowers each time as advertised. Can't see anything in the owners manual. So I plugged in the IID tool and no codes registered. But my battery was showing 11.5v with everything off except the ignition for the IID tool. Is my battery toast? 2006 2.7 TDV6 HSE in Cairns Blue.
Post #630432 Mon Jan 30 2023 3:59pm
gogsy1956
11.5 seems a tad low,,, I would be getting concerned if it was 12.5. As you most likely know,,, check your battery and charging rates,, low battery can cause all manner of issues. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #630441 Mon Jan 30 2023 7:01pm
11.5V is basically flat - it's below 20% charged. I'd put it on a decent smart charger for 24 hours and see what happens. Worth bearing in mind that even if you get it back to showing 12.7V (fully charged) you can still have very little charge capacity in the battery i.e. it might show 12.7V but only have 200A CCA. The only way to check it is to get it put on a proper battery checking device.
What voltage do you see with the engine running? 2012 SDV6 - it's missing a couple of cylinders
Post #630443 Mon Jan 30 2023 7:06pm
Stevepd
I plugged the tool in this morning. Ignition on with everything off = 11.9v. Start the car and watch the live values, which shows 13.5v. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #630467 Tue Jan 31 2023 1:01pm
13.5V with the engine running is low - one would expect c.14.5V. Suspect a tired alternator in need of replacement. 2012 SDV6 - it's missing a couple of cylinders
Post #630473 Tue Jan 31 2023 6:41pm
Stevepd
OK, thanks Wayne. My 30-day count down to service has just popped up, so I'll ask T&S Norman to have a look. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #630486 Wed Feb 01 2023 9:24am
If the car is in access mode, they can do that...... !
Post #630492 Wed Feb 01 2023 1:02pm
Stevepd
A new Exide 1000 battery fitted today. My old battery was showing 700 CCA(EN) down from its 900 original. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #631691 Thu Mar 16 2023 5:58pm
gogsy1956
But you said it was only charging at 13.5V,,,,, needs to be 14.7 or thereabouts,,,, a new battery is not going to fix a low charge rate. Check it again if it's still low I would be looking at an alternator,,, before it let's you down in the middle of nowhere,,,,, just been down that street. 2010 RRS, TDV8
22" overfinch
Post #631694 Thu Mar 16 2023 9:19pm
Stevepd
Sorry I failed to mention that the indie checked the Alternator and said its in good order and working fine. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #631698 Fri Mar 17 2023 9:24am
gogsy1956
Me being a sceptic,,, I don't trust any garage as far as I could throw them. If you have the means to check the charging rate I would do it,, won't cost anything. If you are still seeing less than 14v there is a problem,, mine never deviates from 14.7V,,, the only time it did ( dropping to 13.8V) for a short period,,, the alternator burned out a week or so later. I would certainly be double checking if it is the original unit still in place. 2010 RRS, TDV8
22" overfinch
Post #631708 Fri Mar 17 2023 2:27pm
