| RRSPORT.CO.UK | ||
|  | Home > Faults & Fixes > All warning lights on |
| karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309      | could be the battery voltage is low did you charge the battery up once it went flat | ||
|  Wed Jan 18 2023 7:28pm |
| Samg7188 Member Since: 18 Jan 2023 Location: Reading Posts: 8    | Hi, thanks for your reply, it had a new battery put on it | ||
|  Wed Jan 18 2023 7:36pm |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961      | I would still check the battery and charging rate,,, easiest option and one less area to look at,,,, battery terminals might be worth a look at to make sure they are still secure. 2010 RRS, TDV8
|  Wed Jan 18 2023 7:47pm |
| Samg7188 Member Since: 18 Jan 2023 Location: Reading Posts: 8    | Thanks gogsy, have checked the terminals and they are secure, I will try and check that it's charging correctly tomorrow | ||
|  Wed Jan 18 2023 8:18pm |
| karlos01 Member Since: 02 Jan 2022 Location: norfolk Posts: 309      | I had new battery on mine I still popped it on charge as didn't know how long it had been stood on shelf for | ||
|  Wed Jan 18 2023 10:37pm |
| Samg7188 Member Since: 18 Jan 2023 Location: Reading Posts: 8    | Thats a very good point.. I had a friend plug his obd reader on today, majority of codes were regarding the transfer/gearbox control module and loss of communication with other things (not one code regarding the fuel pump) so am assuming it's a dodgy module or an earthing issue ? | ||
|  Thu Jan 19 2023 1:55pm |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | You said they replaced the battery and the alternator; check the alternator connection as well. What voltage is the alternator putting out? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
|  Thu Jan 19 2023 4:03pm |
| Samg7188 Member Since: 18 Jan 2023 Location: Reading Posts: 8    | Typically my multimeter broke as I went to check the output..I checked over the transmission control module behind the battery, it looked as if it was new inside and out so am thinking I can rule that out.
|  Thu Jan 19 2023 10:13pm |
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961      | I wouldn't necessarily assume it's the alternator but checking the output wouldn't hurt. Ideally if you have a DC clampmeter and an multimeter you can check the current and voltage,, and check resting voltage of the battery,, if they're ok tick them off the list, then start looking for dodgy connections,, especially earths,,, put a couple of temporary ones in from battery to body and engine to see if things improve. After that I might begin towner about the cluster itself. If you can get access to a good reader,,, a few codes may save you sometime. 2010 RRS, TDV8
|  Fri Jan 20 2023 7:54pm |
| Samg7188 Member Since: 18 Jan 2023 Location: Reading Posts: 8    | I really appreciate your help, when I have time this weekend I'll check the alternator... today as I was driving I noticed the audio output was the first thing to go at the same time as an orange brake light (I think abs maybe ) flashing up, followed by a number of faults and lights coming on. I did also notice today that the brake wear sensor is hanging out so disconnected this to rule it out but no difference | ||
|  Fri Jan 20 2023 8:00pm |
| Samg7188 Member Since: 18 Jan 2023 Location: Reading Posts: 8    | Hi guys,  quick update,  I changed the brake light switch a couple of days ago , after driving for probably only a minute the traction control light came on with the yellow (p) and suspension light with the suspension lowering error. So my question is, is it likely that the new switch is faulty or that the old switch isn't reading something before it goes into a tantrum of lights ? If I swap the old switch back on I don't get the initial yellow park and traction control light etc
|  Tue Jan 24 2023 1:52pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Which garage are you using? 2012 SDV6 - it's missing a couple of cylinders
|  Tue Jan 24 2023 5:30pm |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | Could be something really stupid like a brake bulb is out. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
|  Tue Jan 24 2023 6:37pm |
| Samg7188 Member Since: 18 Jan 2023 Location: Reading Posts: 8    | Hi, I originally put it in a local garage nearby that read the fault codes.. I unfortunately don't remember them all or have them written down but they quickly just plugged it in go  to look and its booked in for Saturday. I did the brake switch myself but think it's a red herring as the original now working fine.
|  Tue Jan 24 2023 6:39pm |
| Posting Rules
