Home > Technical > suspension issue
Sween23
United Kingdom 2008 Range Rover Sport TDV6 HSE Rimini Red
suspension issue
hi all, I've been struggling with a little suspension issue for quite a while now.
when I start to drive the rear n/s wheel raises up around 20mm higher than the rest and the front o/s lowers itself down around the same.
when I stop the car and lock it up it then levels itself up straight away by releasing air and dropping the rear n/s level.
I have the IID tool and I can calibrate the suspension level but as soon as I drive its does the exact same.
does anybody have any ideas?
thanks Arron
Post #629623 Wed Jan 04 2023 3:15pm
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
Watch the live values for your height sensors as you raise or lower the truck in graph mode. You may find a sensor giving weird voltage readings. 2009 Range Rover Sport Supercharged
Post #629636 Wed Jan 04 2023 9:08pm
