Home > General > Possibly the best thing Range Rover ever has done
GT RRS
United States
If you’re not doing your own oil changes (at least on L320 5.0 L petrols) and I think most others, do yourself a favor. Grab an OEM fluid evacuator 9.5 L large, or similar, and enjoy doing a topside oil change - without removing skid plates or crawling under your rig.
Ever removed your oil fill cap and noticed a strange circular tube (as you peer down to your timing chain, and wonder when the guides are going to disintegrate), that’s how most dealers drain your crankcase. I’ve done these for years, and it’s a beautiful process. Cartridge filter is topside as well, you’ll probably need an oil filter cap removal tool. Takes longer to fill and not spill then it does to remove the old oil and change filter.
Much easier oil service on this vehicle versus my others, which require crawling under.
Don’t pay $600 plus to the LR stealer, do it in 20 minutes and never grovel on the ground. Happy new year! Vincit qui se vincit
Post #629541 Sun Jan 01 2023 6:58am
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
You cannot do what you suggest on the 2010 or earlier diesel models as there are two sump plugs and draining by the method you suggest would not drain the turbo return line sump. Also it is a good change to see if there are any leaks present when carrying out an oil change.
I believe that mechanics in the US charge US$200 or more per hour. You would go out of business here charging that rate.
I used to get my oil changed at the dealer and it cost AU$200 for the oil (about 10l) plus the filter (about AU$50). Less than AU$350 (just over US$250).
You cant get rid of 10l of oil in this part of the world apart from taking it to the tip as the weekly rubbish trucks will not take 10l oil containers full of oil.
Post #629542 Sun Jan 01 2023 8:35am
I think the double sump was only a thing on the TDV8 due to the turbos being placed lower in the engine bay than would be ideal. The oil return system was devised in order to ensure they drained when running at off road angles. 2012 SDV6 - it's missing a couple of cylinders
Post #629554 Sun Jan 01 2023 7:28pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
Iv been using 1 of those for years, still drop the sump plug every now and again just to make sure there is nothing nasty hiding in there.
Post #629556 Sun Jan 01 2023 8:42pm
GT RRS
United States
Performing all oil services to kick off the new year. Much more fun to remain standing.
Post #629585 Mon Jan 02 2023 11:05pm
SAK335
I bought an electric one at Lidl for £13. It's almost too easy.
Post #629889 Sat Jan 14 2023 11:29am
Mike H
United Kingdom 2012 Range Rover Sport SDV6 SE Santorini Black
Just changed my oil and filter today. So simple and no mess.
Post #629922 Sun Jan 15 2023 2:51pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
I have a 6L one and when I tried it on the RRS I found the suction tube didn’t reach the bottom of the sump so I could only get about 4 and a bit litres out.
I drop the plate now. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, Back on the road again.
1999 BMW Z3 (owned from new) garage queen.
Post #630046 Thu Jan 19 2023 5:33pm
jimbg
Buy a longer tube ? Thumbs Up 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #630049 Thu Jan 19 2023 6:23pm
