![]() | Home > General > L320 screen washer intermittent |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5120 ![]() ![]() ![]() |
Headlight washers work every 6 cycles or something like that.
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1071 ![]() ![]() |
"Headlight washers work every 6 cycles or something like that."
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
I’ve only got the new headlight washer that works now. There is a click from under the dash and the fuse is ok. Baffled.. |
Get someone else if you can to listen outside by pass wheel arch to see if motor can be heard. If yes probably filter as you say.
I can’t hear a pump going unless the headlight washer works so maybe it’s packed up. I’m assuming the window washer pump is separate from the headlight pump.
1 big pump does the headlights.
this is what is looks like in the wheel arch
Fixed. Sort of.. I replaced the pump so it now works but no water from off side headlight washer or near side windscreen washer. I guess the nozzles are blocked so I'll take a look at those at the weekend. |
