![]() | Home > General > Battery failure |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 256 ![]() ![]() |
I’ve just read that the OEM battery was an AGM version. Do I really require this? |
Just ordered a Lion AGM, 3 year guarantee. Hope it’ll be alright… |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
Short runs will definitely run the battery down, especially in this cold weather,,, it never gets a chance to recharge itself. Can you not put a charger on it overnight now and again to keep it topped up. Had the same trouble with mine,, even though it's running now still have in the back of my mind the battery may be a bit weak. 2010 RRS, TDV8
My wife reminded me that this happened about 5 years ago. I thought it would be ok after charging it but it failed again. The current battery is out of warranty by about 3 months. Darn! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9154 ![]() ![]() ![]() |
If it's got down to 11.5V then it's likely to be knackered, especially if it's been run around that level for a while.
I always think about charging it now and again but in reality, I just return from a trip and leave it on the drive until next time.
I've just put SWMBO car on the CTek. The battery was showing 12.3V which is about 60% charged. It's doesn't do much running these days and often just does short journeys - although it has had a couple of half hour runs this week - so is prime "target" for a low battery.
As I started to change the battery, it began to rain. The new battery was in the boot so I closed the tailgate and went inside for a cuppa. Once it had stopped raining, I opened the bonnet and removed the old battery; went to get the battery out of the boot and of course, the electronic lock didn’t work…sigh! Manoeuvring the battery out of the boot via the back seats wasn’t easy. |
mike54 Member Since: 19 Dec 2020 Location: NW Posts: 23 ![]() ![]() |
invest in a CTEK trickle charger, they're cheap and worth the money ![]() |
The worry about getting a trickle charger is that I would use it regularly for the first month or so but then it would just stay in its box. It’s just the way stuff happens… |
Yeah I get that. You can make life easy though by fitting a connector to your battery so its just one plug in rather than messing with croc clips. |
Just so long as you don't come on here in a year's time and complain about your battery... ![]() ![]() 2008 TDV8 - it was a labour of love and is much missed |
