![]() | Home > Technical > L494 Air Bag light again |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
There is a known problem with the airbag wiring loom being too short.
Crs Member Since: 04 Sep 2022 Location: Hampshire Posts: 82 ![]() ![]() ![]() |
Ok thanks I will give it a go, you would think that this would be a re call |
Best Yet Member Since: 02 Feb 2018 Location: W.MIDS Posts: 42 ![]() ![]() |
I have this same problem on 2015/16 autobiography hybrid V6 |
Have you had any luck with the problem |
Will be investigating in the morning all being well and will report back asap |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 549 ![]() |
Had exactly the same on my RRS.. and can confirm it is the seat wiring harness … |
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 123 ![]() ![]() |
I too had the same problem, connector needed cleaning under the seat. I found this helped to locate the connector.
Ok, put the drivers seat as far forwards Well all most, it sounded like the wires under there were getting to stretched so I stoped, I then pressed my pre set button so the seat went back to my position, stoped the engine, then re started and the air bag light went out, I know I have probably only moved the offending connection under there but let’s see how long it lasts. |
Just a quick update not been able to look at my same fault due to weather and other commitments |
What I thought was a quick fix did not work, light back on, if I mess about with wires under the seat it goes off sometimes but reappears, got a telling off from the wife today for the obscene language after it reappeared to day. |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595 ![]() ![]() |
Got so fed up with ours i put a piece of black insulating tape on the clocks |
Good idea, I was just going to say what about the mot. |
