![]() | Home > Technical > RRS 2012 And Strange Electronics Issue(s) |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5117 ![]() ![]() ![]() |
Certainly not a auto electrician, but I think I would initialy check the new battery, could be a bit suspect.
Definitely get the battery checked. Just cause it’s new, doesn’t mean it works. Seen plenty of new out of the box parts fail/be faulty.
Workalot Member Since: 08 Feb 2021 Location: Newcastle Posts: 9 ![]() ![]() |
Ok, first thing - the car's VIN indicates it is an 2013 RRS L320 3.0 diesel, and not an RRS 2012 as I reported. It was built July 2012.
Could potentially be the gauge cluster is faulty and needs to be repaired/replaced. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
To keep the story going.
Just to add...
Thought S/J was abbreviation for Splice Joint where several wires are joined together, only downside is they could be located anywhere in the circuit I think.
Yes - 'splice joint'. My immediate thinking was 'solder joint' - but that would never do in an automotive environment. |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 142 ![]() ![]() |
The first thing I'd check is the state of your battery under load. You need to visit a car electrician or a battery retailer with the necessary equipment to check the battery under load. Next, I'd be looking at the integrity of the earthing points. It's surprising how many weird issues are caused by poor earthing, and basic troubleshooting methods ignored by the masses. |
Want to keep a dialogue going...
Did you ever take a look for that white connector I mentioned in the rear?
A result!
A lot don’t want to tackle it because it’s often a lot of hours to track down the problem. We tore apart a 2010 chasing that connector in the rear. Some three days of checking connections, modules, etc. that racked up a pretty big bill. A bill the customer didn’t want to pay. So shops are reluctant to go diving into things like that knowing it’s going to be a large bill that many customers think should only magically take a few minutes to diagnose and fix. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Yes NoExpert, I agree, and understand, that shops will eschew CANbus problems. Two had done this in my case.
