Home > Technical > Steering wheel vibration when braking |
3hcp Member Since: 04 Nov 2021 Location: Devon Posts: 77 |
I’d check the track rods for play 2015 RRS DIESEL HYBRID |
Thu Nov 24 2022 6:43pm |
giacomo.m Member Since: 04 May 2016 Location: Roma Posts: 9 |
Thank you 3hcp
Thu Nov 24 2022 6:58pm |
I had that on BMW X3 turned out to be discs which I bought off eBay and assumed were ok but weren’t 2015 RRS DIESEL HYBRID |
Thu Nov 24 2022 9:35pm |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 408 |
Have you had a 4x wheel tracking done? Barrie.
Fri Nov 25 2022 8:19am |
What is it ?
Fri Nov 25 2022 8:22am |
https://www.ms-autocare.co.uk/hunter-4-wheel-alignment
Fri Nov 25 2022 9:06am |
Ah ok,
Fri Nov 25 2022 2:17pm |
Have you checked the tyres for feathering,first thing to do is swap front wheels for rear & vice versa & see if that makes any difference,also are you getting any road noise like a wheel bearing as gone.? Andy.
Fri Nov 25 2022 3:46pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 122 |
Warpped brake discs possibly. Need to check their run-outs |
Mon Nov 28 2022 2:21am |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 192 |
Mine was and has been front rotors, like clock work they get replaced every 2 years regardless of miles on the car. The good news is it started while car was under warranty and it’s back on Dec 4 to the dealer for another set. I’ve never replaced brakes on any other car, truck, etc like this before. I’ve gone from 13,000 to 5,000 miles a year same issue.
Tue Nov 29 2022 3:47pm |
Hi all,update
Mon Jul 17 2023 12:11pm |
There’s also the issue of brake pads, especially non original cheap ones. These cars were never made to run on a cheap budget, unfortunately |
Thu Jul 20 2023 4:56am |
I’ve balanced 000’s of wheels on Rangerovers & never had a problem,even using the cheaper end Chinese balancers. Andy.
Thu Jul 20 2023 6:24am |
Thank you erickwan, i mounted ATE front disc brakes and pads..... maybe the Brembos are better ? Giacomo |
Thu Jul 20 2023 7:30am |
